Mazda MX-5 Miata Turn Signal / Tail Light LEDs! See Installed Comparison Photos! - ClubRoadster.net
Go Back   ClubRoadster.net > SPONSORS > Diode Dynamics
Old 06-25-2014, 10:24 AM   #1 (permalink)
Supporting Vendors
Diode Dynamics's Avatar
Lightbulb Mazda MX-5 Miata Turn Signal / Tail Light LEDs! See Installed Comparison Photos!
Miata LED Turn Signals
SMD60 Shown:
Click to order or for more information:
1990-1997 Front Turn Signal LEDs
1999-2005 Front Turn Signal LEDs
2006-2008 Front Turn Signal LEDs
2009-2014 Front Turn Signal LEDs
Bulb Design:
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Included in your order is TWO BULBS.
Hyperblink Fix: The turn signals on most vehicles will begin to blink fast (hyperblink) when LED bulbs are installed. This is because LEDs use less power than the original bulbs, so your vehicle thinks that the bulb is out. There are two ways to fix this:
Resistor Kit: This is a universal way to fix the issue, and will work for any vehicle. By adding a resistor to the bulb's circuit, you can mimic the power consumption of the original bulb, and return the vehicle to normal turn signal speed. The installation takes 10-15 minutes, and involves making two simple connections. Everything you need is included in the kit. If you have both front and rear LED turn signals, you usually only need one set of resistors, on the front or rear, to create enough resistance for the turn signal circuit.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty. For more information, please view the FAQ guide.
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Diode Dynamics is offline   Reply With Quote Quick reply to this message
Old 06-26-2014, 10:40 AM   #2 (permalink)
Supporting Vendors
Default Re: FS: Turn Signal LEDs *Switchback Options* -Same Day Shipping!
We have a Miata in the studio right now
Nick C.
Last edited by Diode Dynamics; 08-14-2014 at 12:04 PM. Reason: Testing update: 8/14/2014
Old 07-04-2014, 01:11 PM   #3 (permalink)
ssand1's Avatar
Just finished install on my 1995, love them. You were right about the resistor getting hot, wow does it.
All in all a nice upgrade, thanks again.
ssand1 is offline   Reply With Quote Quick reply to this message
Old 07-07-2014, 09:52 AM   #4 (permalink)
Supporting Vendors
Thanks for ordering with us!
Post some pictures when you get a chance!
Nick C.
Old 07-22-2014, 09:21 AM   #5 (permalink)
miatapasta's Avatar
How man lumens are these compared to incandescent bulbs?
1.8 swapped vintage inspired roadster
2000 Outback - off road & daily duty
miatapasta is offline   Reply With Quote Quick reply to this message
Old 07-22-2014, 10:18 AM   #6 (permalink)
Supporting Vendors
Which bulb model are you referring to?
We have a variety of options for the turn signal locations
Nick C.
Old 09-12-2014, 09:05 PM   #7 (permalink)
AlterEgo's Avatar
Would I be able to buy some to convert my bulbs in my Turn signal intakes?
1995 M edition
AlterEgo is offline   Reply With Quote Quick reply to this message
Old 09-13-2014, 12:49 PM   #8 (permalink)
Supporting Vendors
It would probably be a 194 bulb, so any time! http://www.diodedynamics.com/store/l...-size/194.html
Old 09-17-2014, 10:07 PM   #9 (permalink)
MOABmiata's Avatar
How do these look in the stock turn signal housings? The pictures you showed appeared to be clear/JDM housings if I'm not mistaken. Is that necessary?
1994 Laguna Blue-FCM coilovers, HDHCHT Roll bar, 15x8 6UL
BEGi MOAB twin screw supercharger @ 9psi: 214whp/174wtq
MOABmiata is offline   Reply With Quote Quick reply to this message
Old 09-18-2014, 09:49 AM   #10 (permalink)
Supporting Vendors
You won't be able to install the switchbacks in an amber housing, if that's what you were wondering?
The clear housings are required for switchbacks. We have single color amber bulbs for the factory turn signals
Nick C.
Old 09-19-2014, 05:05 PM   #11 (permalink)
MOABmiata's Avatar
Nick C.
I didn't mention an amber housing, I'm referring to the stock NA turn signals, which are white/diffused.
Like so
I don't see why they wouldn't work, but I don't make the product which is why I ask.
Old 09-19-2014, 05:09 PM   #12 (permalink)
Supporting Vendors
Like so
My mistake, I thought you were referring to putting switchbacks in an amber housing lol
They are intended for clear housings and we definitely have the sizes you need for your stock housings
Nick C.
Old 11-04-2014, 11:18 AM   #13 (permalink)
PTAD1's Avatar
Question: Do these also work for what Miatas basically have as parking lights? Would those be cool white when they're on, and cool white when they flash?
Also, what do you mean by switchback?
Follow me on Instagram @2_chase
1991 Miata: Classic Red, Lowered, BBS, OEM Plus
PTAD1 is offline   Reply With Quote Quick reply to this message
Old 11-04-2014, 09:12 PM   #14 (permalink)
Supporting Vendors
The switchbacks are a dual function bulb, that stay white when operating as a running light and flash amber when the turn signal is used.
If your vehicle doesn't have a dual filament turn signal / running light bulb, we have some bright amber options as well
Nick C.
Old 11-04-2014, 10:14 PM   #15 (permalink)
PTAD1's Avatar
Nick C.
How can I tell if it's dual filament?
I am asking because I really want these for my car but want to be sure they work first
Old 11-05-2014, 10:00 PM   #16 (permalink)
Supporting Vendors
Give us a call at your earliest convenience and we can provide you with more information on a switchback setup: (314) 205-3033
Nick C.
Old 04-14-2015, 09:57 AM   #17 (permalink)
Supporting Vendors
Recent comparison with our tail light LEDs!
Nick C.
Old 04-15-2015, 03:59 AM   #18 (permalink)
Default Re: FS: Miata Turn Signal LEDs *Switchback Options* -Same Day Shipping!
Hi Nick, any ETA on when the HP24 switchbacks are going to be back in stock?
essel is offline   Reply With Quote Quick reply to this message
Old 04-15-2015, 10:54 AM   #19 (permalink)
Supporting Vendors
They are expected to arrive April 20th (est.)
We will post an update when they are available on the site
Thanks!
Nick C.
Old 04-15-2015, 10:42 PM   #20 (permalink)
Sweet, sounds good. Thanks!
Old 04-16-2015, 09:50 AM   #21 (permalink)
Supporting Vendors
You're welcome!
Nick C.
Old 07-10-2015, 04:47 PM   #22 (permalink)
dnationb's Avatar
Just ordered a set of the switchbacks. Looking forward to installing them, thanks!
dnationb is offline   Reply With Quote Quick reply to this message
Old 07-13-2015, 09:52 AM   #23 (permalink)
Supporting Vendors
Thank you for ordering with us!
Looking forward to seeing your pictures with them installed
Nick C.
Old 10-16-2015, 02:42 PM   #24 (permalink)
Supporting Vendors
Meet our newest LED bulb replacement, the HP48:
Available in 1156/7 - 3156/7 - 7440/3 sizes
Old 05-10-2016, 09:45 AM   #25 (permalink)
Supporting Vendors
Default Re: Mazda MX-5 Miata Turn Signal / Tail Light LEDs! See Installed Comparison Photos!
Customer submitted image
Nick C.
Old 08-25-2016, 06:47 PM   #26 (permalink)
Supporting Vendors
Diode Dynamics Universal RGBW Demon Eyes, the only made in the USA option, for all projector housing applications!
RGBW? Demon Eyes (Universal)
Old 11-15-2016, 09:52 AM   #27 (permalink)
Supporting Vendors
Diode Dynamics Store
Old 11-18-2016, 06:05 PM   #28 (permalink)
Supporting Vendors
Questions about automotive lighting? Give our team a call!
(314) 205-3033
Old 11-22-2016, 04:24 PM   #29 (permalink)
Supporting Vendors
The 2016 Black Friday Sale Starts Now!
20% off orders $100 or more using code: BLACKFRIDAY
*Cannot be combined with other discounts
Old 11-23-2016, 08:52 PM   #30 (permalink)
Supporting Vendors
The 2016 Black Friday Sale continues!
