Mazda MX-5 Miata Fog Light LED Bulbs! Plug & Play Install! Same-Day Shipping! - ClubRoadster.net
Go Back   ClubRoadster.net > SPONSORS > Diode Dynamics
Old 09-18-2014, 10:34 AM   #1 (permalink)
Supporting Vendors
Diode Dynamics's Avatar
Lightbulb Mazda MX-5 Miata Fog Light LED Bulbs! Plug & Play Install! Same-Day Shipping!
Mazda Miata MX-5 Fog Light LED Bulbs
We carry LED bulbs for replacement of your fog lights, in all major sizes. They are available in HP, XP, and XML styles. This will make your Miata's fog lights a nice bright white (or yellow)!
Plug and play installation, replace the bulb and you are good to go!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
XML2: 1410 lumens. Much brighter than factory. These are bright!
*XML2 is available in 3000K Yellow / 4000K / 5000K / 6000K Color Temperatures
Bulb Design
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
XML2: NEW! Two opposing genuine CREE XM-L2 chips, driven at high power by self-contained regulator unit, in an attractive cast-aluminum housing. Fully waterproof, non-polar, modular design.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Miata).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
2004-2005 MX-5 Miata
2006-2016 MX-5 Miata
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics is offline   Reply With Quote Quick reply to this message
Old 11-26-2014, 01:34 PM   #2 (permalink)
DaleNixon's Avatar
Default Re: FS: Fog Light LED Bulbs! Several Brightness Options! New XML2 Added!
Were the fogs changed for 04-05? I'm assuming these wouldn't work in my 01 fog lights?
DaleNixon is offline   Reply With Quote Quick reply to this message
Old 11-28-2014, 10:39 AM   #3 (permalink)
Supporting Vendors
Unfortunately, the 2001-2003 Miata uses an H1 sized bulb which is a rather small size. We don't offer the XML2 or XP80 for that bulb model yet.
There isn't enough room for proper heat shrink on the H1/H3/880/881 sized bulbs for the XP/XML2 LED styles
Nick C.
Old 02-10-2015, 05:33 PM   #4 (permalink)
Haerie Ballsagna
concealer404's Avatar
Anything for 99-00 fogs?
PM me for Amsoil fluids.
Originally Posted by Corky Bell
Understanding how it works and even it's limitations doesn't really matter.
Gotta tell you, Quaker Oats with Jose is a real treat.
corky
concealer404 is offline   Reply With Quote Quick reply to this message
Old 02-10-2015, 05:48 PM   #5 (permalink)
Supporting Vendors
We have several bulb options available for nearly every major size
Nick C.
Old 04-15-2015, 05:27 PM   #6 (permalink)
Default Re: FS: Miata Fog Light LED Bulbs! Several Bulb Options! New XML2 Added! Plug and Play!
The fogs are $40 for a 2007 and yellow is free but it's only compatible with the lights that are at least $50 extra?
BuzzedAldrin is offline   Reply With Quote Quick reply to this message
Old 04-15-2015, 05:34 PM   #7 (permalink)
Supporting Vendors
The bulb size is different for each generation of Miata
The older generation uses an H1 bulb, which is considerably smaller than the 9006 & H11 bulb size that the newest generations use.
Unfortunately, the H1 bulb size is too small to fit enough heatsink for higher powered LED options like the XML2 and XP80 we carry.
If you are looking for a yellow H1 bulb model that produces usable output, you'll want to use a quality halogen bulb or 35 watt HID conversion kit
Feel free to give us a call if you have any questions: (314) 205-3033
Thanks!
Nick C.
Old 03-24-2016, 03:17 PM   #8 (permalink)
Supporting Vendors
Default Re: Mazda MX-5 Miata Fog Light LED Bulbs! Plug & Play Install! Same-Day Shipping!
Customer Submitted photo with Yellow XML2 Installed
Nick C.
Old 01-05-2017, 03:32 PM   #9 (permalink)
Supporting Vendors
Questions? Chat with an expert on our site!
www.diodedynamics.com
Old 01-10-2017, 10:54 PM   #10 (permalink)
Supporting Vendors
Contact@diodedynamics.com
Old 01-11-2017, 09:23 PM   #11 (permalink)
Supporting Vendors
Diode Dynamics is on SnapChat!
Nick C.
Old 01-12-2017, 04:25 PM   #12 (permalink)
Supporting Vendors
PM Responses sent!
Thanks,
Nick C.
Old 01-20-2017, 12:49 PM   #13 (permalink)
Supporting Vendors
Old Yesterday, 11:51 PM   #14 (permalink)
Supporting Vendors
Tags
immense penis, premium succ
