Diode Dynamics: Gauge Panel Light LEDs for 1993-1997 Mazda MX-5 Miata! See Installed Pics! No Hotspots! - ClubRoadster.net
Go Back   ClubRoadster.net > SPONSORS > Diode Dynamics
Old 10-28-2015, 04:49 PM   #1 (permalink)
Supporting Vendors
Diode Dynamics's Avatar
Lightbulb Diode Dynamics: Gauge Panel Light LEDs for 1993-1997 Mazda MX-5 Miata! See Installed Pics! No Hotspots!
Gauge bulbs are used to illuminate the gauges on your dash board. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the gauges with modern, cool white light. By changing your gauge bulbs to LED, you can easily add this luxury look to your vehicle!
The installation is 100% plug-and-play, just replace your factory bulbs!
Bulb Design
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
Fitment. All bulbs use a quality inject-molded 194/168 T10 terminal, with a full-size base connector and proper pin alignment, designed for exact replacement of your factory 194 bulb. Just remove the old bulb, and plug in the new LED.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP3: Much brighter than OEM bulbs. These are bright!. (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Diode Dynamics is offline   Reply With Quote Quick reply to this message
Old 01-07-2016, 06:03 AM   #2 (permalink)
Default Re: Diode Dynamics: Gauge Panel Light LEDs for 1993-1997 Mazda MX-5 Miata! See Installed Pics! No Hotspots!
What's different about the 90-92 miata?
Burnitwithfire is offline   Reply With Quote Quick reply to this message
Old 01-18-2016, 04:07 PM   #3 (permalink)
Supporting Vendors
We haven't had one in our studio to confirm the sizes or fitment. There's a good chance it's the exact same.
Nick C.
Old 11-25-2016, 12:39 PM   #4 (permalink)
Supporting Vendors
Don't miss out on this year's biggest sale!
Use code: "BLACKFRIDAY" for 20% off your entire order!
*Cannot be combined with any additional codes
Thank you,
Nick C.
