Diode Dynamics: DOT 7" LED Headlight Housings / See Installation Video! - ClubRoadster.net
Go Back   ClubRoadster.net > Vendors > Diode Dynamics
Old 11-15-2016, 10:58 AM   #1 (permalink)
Supporting Vendors
Diode Dynamics's Avatar
Arrow Diode Dynamics: DOT 7" LED Headlight Housings / See Installation Video!
(Black Bezel Shown)
How to Install DOT 7" Headlights
Our DOT 7" Headlights are a true OEM-grade LED replacement for any factory 7" headlight housing, like the ones found on the Miata.
Available with chrome or black bezels, this headlight is a direct fit, using standard factory brackets (sold separately). Integrated Anti-Flicker modules allow for error-free installation. - no adapter required. With both H4 and H13 size connectors, installation is plug and play - simply replace the factory headlight housings.
*FOR USDM Models Only
The integrated dual projector lens distributes light in a wide, even pattern for the low beam, and side-mounted reflectors provide intense light for the high beam, to illuminate far down the road, making them compliant with DOT and SAE vehicle safety and quality standards for use on-road. With a durable poly-carbonate lens, aluminum housing, and constant-current drive circuit, these LEDs will be durable and reliable for years to come.
Check out our dealer locator tool to find a dealer near you:
Find a Diode Dynamics Dealer
DOT 7" LED Headlights (pair)
All Diode Dynamics products are backed by our 3-year limited warranty
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call us: (314) 205-3033
Thanks for looking!
Nick C.
Diode Dynamics
Diode Dynamics is offline   Reply With Quote Quick reply to this message
Old 11-16-2016, 08:46 AM   #2 (permalink)
Supporting Vendors
Default Re: Diode Dynamics: DOT 7" LED Headlight Housings / See Installation Video!
Customer Submitted Image Wrangler - Black Bezel Option
They look even better on an NA Miata IMO!
Nick C.
Old 11-17-2016, 01:57 AM   #3 (permalink)
Closed Shell Syndrome
iRoadster's Avatar
And these are three times as much as the exact same lights elsewhere, why??
Good to have you on board the MR forum welcome
There's no "turned into." I've been a nerd for 38 years.
iRoadster is offline   Reply With Quote Quick reply to this message
Old 11-17-2016, 07:44 AM   #4 (permalink)
Supporting Vendors
While we do create many of our own items from the ground up, we still offer products like this lamp for customers who are looking for a more reasonably-priced option, but still with the assurance that it will perform and work well, with a solid 3-year warranty.
We conduct all of our own compliance testing here at our facility in St. Louis, including photometric beam pattern testing, humidity/extreme temperature testing, corrosion testing, lumen maintenance testing, and electrical transient testing.
While you indeed may be able to find comparable options from other US-based sellers that work well, I can assure you that no $100/set ebay-special option will come close to this lamp in output. The vast majority of "value" 7-inch lamps are not DOT compliant. The output at that price range is terrible. You may be able to find comparable options for a lower price, and that's certainly your choice.
Quite simply, we only provide products that will work well for our customers. To make sure of that, we spend a lot of time in product testing, so we know that this lamp will work well for years to come. That takes real time and money for our engineering team. We make that investment because many of our customers do find value in that assurance of quality. Of course, it may not be valuable to everyone.
Old 11-17-2016, 02:01 PM   #5 (permalink)
Labora's Avatar
These are actually cheaper than some that I have been considering which are DOT compliant...
How many Lumens do these put out?
1994 Mustang Cobra - Garage Shelf
2012 Mazda 3 - Daily
Labora is offline   Reply With Quote Quick reply to this message
Old 11-17-2016, 02:13 PM   #6 (permalink)
Supporting Vendors
The low-beams produce 1,100 lumens, high beams produce 1,650 (measured). The actual lumen output tells just one part of the story. The design of the optics result in a significant improvement in hotspot lux over the factory halogen units. This means you'll be able to see farther down the road, which is needed for safety. The output itself is focused properly onto the road vs. scattering it everywhere like the lower quality options on the market.
Here's a recent output shot from our friend LSX Willys:
Nick C.
Old 11-25-2016, 10:40 AM   #7 (permalink)
Supporting Vendors
Don't miss out on this year's biggest sale!
Use code: "BLACKFRIDAY" for 20% off your entire order!
*Cannot be combined with any additional codes
Thank you,
Nick C.
Old 11-28-2016, 01:05 PM   #8 (permalink)
Supporting Vendors
Don't miss out on this year's biggest sale! Sale Ends Tonight (Midnight CST)
Use code: "CYBERMONDAY" for 20% off your entire order!
Thank you,
Nick C.
