key stuck in ignition - ClubRoadster.net
Go Back   ClubRoadster.net > DISCUSSION > General Automotive Chat
General Automotive Chat If it doesn't fit in another category, post it here. Polls can be created here as well.
Old 05-27-2012, 05:23 PM   #1 (permalink)
Default key stuck in ignition
hi i have a 1991 miata my dumbass friend found a random key in my glove box and tried putting it in the ignition it turned on but when he turned it off the key is now locked in and wont come out at all any advice or little tricks that'll get it out? thanks
Reckless is offline   Reply With Quote Quick reply to this message
Old 05-27-2012, 05:36 PM   #2 (permalink)
(Adam)'s Avatar
Default Re: key stuck in ignition
Get new friends first.
(Adam) is offline   Reply With Quote Quick reply to this message
Old 05-27-2012, 05:44 PM   #3 (permalink)
enormous gay swords.
spitefulcheerio's Avatar
Hit it with a hammer really hard
TOVE LO
clubused2ownacivic.net
Originally Posted by jpatrick
Not nearly as good as Cherrio's Hole.
You made your phycho bed. Go fuck yourself in it.
spitefulcheerio is offline   Reply With Quote Quick reply to this message
Old 05-27-2012, 06:03 PM   #4 (permalink)
you guys dont even know i never knew such anger could arise from me
Old 05-27-2012, 06:05 PM   #5 (permalink)
(Adam)'s Avatar
Are you a redhead?
Old 05-27-2012, 06:08 PM   #6 (permalink)
well if saying i was born without a soul does that answer it
Old 05-27-2012, 06:16 PM   #7 (permalink)
Accepting donations.
adamvanxxx's Avatar
Make him buy you a new tumbler and locks.
adamvanxxx is offline   Reply With Quote Quick reply to this message
Old 05-27-2012, 06:23 PM   #8 (permalink)
ApexRacer's Avatar
Hit the lock or the friend?
-Glenn
Friends don't let friends early Apex!
ApexRacer is offline   Reply With Quote Quick reply to this message
Old 05-27-2012, 06:27 PM   #9 (permalink)
Cxmoney's Avatar
If you cant get it out, i have a complete ignition with 2 keys and a trunk lock i will sell you. Just remove your old one and throw this one on, then no issues. Pm me if interested
Cxmoney is offline   Reply With Quote Quick reply to this message
Old 05-27-2012, 07:12 PM   #10 (permalink)
JXOXHXN626's Avatar
lol new friends
JXOXHXN626 is offline   Reply With Quote Quick reply to this message
Old 05-27-2012, 07:19 PM   #11 (permalink)
Lol!
TOVE LO
Old 05-27-2012, 07:30 PM   #12 (permalink)
Remy's Avatar
Try wiggling the steering wheel and removing the key at the same time.
Originally Posted by Mike Donnelly
Kill Whitey
Remy is offline   Reply With Quote Quick reply to this message
Old 01-21-2014, 02:47 PM   #13 (permalink)
marcoSTEEZ's Avatar
Okay I didnt feel like started a new thread for this, as I seemingly had the same problem. The wheel hasnt locked, it turns freely. Ive tried twisting 900 different ways. No luck. Ive read in a few Spec Miata threads that you have to drill into the ignition cylinder and remove a spring/pin for the wheel lock to disengage. Im okay with doing whatever I have to do to get this damn key out. Most people are saying get a new ignition switch/whole assembly all together. SOME HELP WOULD BE GREAT. NAWMSAYIN
marcoSTEEZ is offline   Reply With Quote Quick reply to this message
Old 01-21-2014, 03:01 PM   #14 (permalink)
Sponsor
Chris@Moss's Avatar
This isn't exactly helpful, but my original key finally started to bend when I used it on the door and trunk locks, that made me nervous so I got a new key. I wonder if your key was bent slightly so that you could put it in the ignition but maybe turning it helped bend it more, and now the key is just physically stuck in the cylinder? If that's the case the whole thing would need to come out of the column, and new parts needed. Sorry I have never experienced the OPs problem or yours. Good luck.
Chris Knight
Chris@Moss is offline   Reply With Quote Quick reply to this message
Old 01-21-2014, 05:50 PM   #15 (permalink)
marcoSTEEZ's Avatar
Thanks Chris for the input, but the key seems like its willing to slide out IF.. it could click past the off postion. It needs to come down one more click, but won't. The key slides and wiggles in the slot, but wont rotate.
Old 01-23-2014, 09:09 AM   #16 (permalink)
marcoSTEEZ's Avatar
bump guys.
Old 01-23-2014, 01:58 PM   #17 (permalink)
Sponsor
Chris@Moss's Avatar
Stupid question: is the car an automatic and it's not in park?
Ok now that we're past that, lol: have you tried using a hammer and lightly tapping on both the face of the ignition cylinder and then also the end of the key? Might be that a tumbler is stuck. Try that?
Chris Knight
Old 01-23-2014, 11:28 PM   #18 (permalink)
marcoSTEEZ's Avatar
ive lightly tapped/WD40'd/yanked/giggled/wiggled/probed/beatthelivingshit out of the cylinder. Drilled the hole that removes the spring and pin for the wheel lock. No luck. Im jus gonna get a new assembly from friend. This f*ckin thing is driving me insane.
