wiring in extra guages ..... help please - ClubRoadster.net
Old 02-01-2008, 08:39 AM   #1 (permalink)
retrorocket's Avatar
Default wiring in extra guages ..... help please
when it comes to electrics I am completely useless so please bear with me .....
I have got volt meter / oil temp / oil pressure guages ( smiths quadrant classic ) to put in my radio console panel and have the apropriate senders already fitted to a oil filter sandwich plate ready to go.
I am okay with the back lighting for the three guages as I can just splice into the ashtray illumination as the ashtray is long gone, however I have no idea what to connect the two contacts on the back of each guage to !!? presumably one on each of the oil guages goes to the appropriate sender and the othger to a switched supply, where do I get that from ?
also do I need to earth them, there are only two connectors on each of he guages
any help much appreciated
TIA
retrorocket is offline   Reply With Quote
Old 02-01-2008, 08:51 AM   #2 (permalink)
silverslider's Avatar
Default Re: wiring in extra guages ..... help please
just tap into the radio switched power since it is close by. you could also just get illumination from the radio harness also
silverslider is offline   Reply With Quote
Old 02-01-2008, 08:52 AM   #3 (permalink)
... I have relocated my radio under the glove box don't ask !!!
Old 02-01-2008, 08:55 AM   #4 (permalink)
levnubhin's Avatar
I have 1 of my guages tapped in to the radio harness and the other 2 into the dimmer switch.
levnubhin is offline   Reply With Quote
Old 02-01-2008, 09:14 AM   #5 (permalink)
Finger lickin' good...
LostSoulMiata's Avatar
You can use the ashtray wire, but it's a little small of gauge of wire. I personally used my HVAC lighting wires due to a bigger gauge wire and that it controlled multiple lights. A good ground would be nice on the chassis for more precise movement of the gauge readings. As far as the sending unit, I know it should be connected to a switched power source. Without knowing which brand or model you have, it's a little difficult to pinpoint exactly.
Andrew
- '98 Honda Superhawk
- '88 Yamaha YSR50 - "Play Thing"
'78 Honda CB750F SOHC SuperSport - "Lucky 13"
LostSoulMiata is offline   Reply With Quote
Old 02-01-2008, 09:19 AM   #6 (permalink)
guages are smith classic quadrant ... http://www.holden.co.uk/displayprodu...&pCode=070.006
