hid retro fit in NA - ClubRoadster.net
Old 02-27-2008, 06:34 PM   #1 (permalink)
Default hid retro fit in NA
has anyone done this yet, i think im gonna try it, but i want to see if anyone else has first.
swales is offline   Reply With Quote
Old 02-27-2008, 09:01 PM   #2 (permalink)
jnshk's Avatar
if you mean just popping a H4 rebased HID plug-n-play kit, plenty of people have done it. generally, the only relative successes have been using Cibie or Hella housings though. you've got to start with quality optics to have quality lighting.
if you mean fully retrofitting some HID optics (either from another vehicle, or from a universal source like the Hella 90mm), then I don't think anyone has done this on a miata, except for maybe some one-off low-profile setups using projectors. i would think that using a Hella 90mm bi-xenon in the Moss lo-pro kit would be a simple and nice (though somewhat expensive) way to get good HID lighting. plus you could then use the area that had originally been for the high beam projector and mount a cold-air-induction hose for the intake/engine bay. that's one of the ideas i've been mulling over personally.
the other option would be to do something like this: http://forums.nicoclub.com/zerothrea...postid=2681590
but with some 7" round housings instead of the rectangles. and assuming that you're relatively careful and skilled, you can make one that looks a lot more pleasing to the eye than that one, i should hope.
"...all the best stuff is made in Japan." Marty McFly, Back to the Future III
Chaste White 1997 NA. My other car is a Ford V6 powered 1958 Volvo moneypit... err, PV444.
jnshk is online now   Reply With Quote
Old 02-27-2008, 10:23 PM   #3 (permalink)
Default Re: hid retro fit in NA
bi-xenon won't fit (maybe it will with some mods). Even though its marketed under the 90mm line, its mounting is not exactly the same as the true 90 mm lamps.
The xenon low beam in a Moss setup is nice, though. I have it and love it.
natepartlan is offline   Reply With Quote
Old 02-27-2008, 10:41 PM   #4 (permalink)
RotorNutFD3S's Avatar
+1
RotorNutFD3S is offline   Reply With Quote
Old 02-27-2008, 10:42 PM   #5 (permalink)
jnshk's Avatar
Thanks for the heads-up! The physical dimensions are pretty close, right? Is it mainly just a problem of the actual mounting locations or surface? Perhaps something that could be corrected with an adapter bracket/plate or some creative drilling and tapping?
Old 02-28-2008, 02:00 AM   #6 (permalink)
loanpro's Avatar
I have Raybrig headlight housing and just popped some HID's on it...
loanpro is offline   Reply With Quote
Old 02-28-2008, 07:27 AM   #7 (permalink)
Not sure how much modding would be required. You can go to http://www.rallylights.com/hella/90mm_modules.asp for pics and measurements.
I've driven bi-xenons in other cars and love it, but you have to sit down and really think about if spending that amount of dough just for HID high beam is worth it to you. Other plans/mods may be affected so your situation is unique to yourself, but how often do any of us really use our high beams?
Old 02-28-2008, 07:08 PM   #8 (permalink)
jnshk's Avatar
I actually use my high beams with relative frequency, but I still have yet to determine if HIDs are even worth the $$$ for me personally. I've been exceedingly happy with the 85w/105w H4 Narva bulbs and Cibié e-codes that I've been using on my '58 Volvo, and to be honest the sealed beams that I've got in the Miata right now are usually sufficient for most situations. I think it's just that I've got the Tim Allen syndrome... needs moar powar!
Old 02-29-2008, 07:09 PM   #9 (permalink)
mr_mazda329's Avatar
I have HID's with my Moss Low pros. Outstanding!
http://forum.miata.net/vb/showthread.php?t=266052
97MontegoBlue FM sways,FM butterfly Brace,Ohlins DFVs ,Boss frog roll,Borla Catback,JR header, JRSC M45 14x7 +19 Enkei RPF1's 195/60R14 ZE-912's
09 MS3 CWP NGR Type-S BPV, Cobb SRI, CorkSport CBE, Dashhawk, TWM Shifter Bushings, HTP Turbo Inlet, Denso ITV22, TRZ Poly MM, CXracing FMIC, Cobb AP Stg1 SF/FMIC
mr_mazda329 is offline   Reply With Quote
