CD player install please help! YELLOW wire goes were? - ClubRoadster.net
Old 07-27-2009, 06:47 PM   #1 (permalink)
Default CD player install please help! YELLOW wire goes were?
ok so I got this cd player dvd player. When i put the yellow wire to the Power wire(red wire) it turns on and the dvd screen comes out and works and everything. But it stays on even wit the key out of the ignition and starts smelling like its about to smoke. Does anyone know which wire the yellow one goes to as it only turns on with the yellow one connected. The yellow one according to the CD player label say memory back up 12V.
If you guys need pics ill take one let me know thanks for the help.
RacingBeatMx-5 is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 06:51 PM   #2 (permalink)
nannerpus's Avatar
Default Re: CD player install please help! YELLOW wire goes were?
Originally Posted by RacingBeatMx-5 View Post
dvd
:rolleyes:
nannerpus is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 06:53 PM   #3 (permalink)
What? Its a touch screen dvd/cd player. Where does it go.
Old 07-27-2009, 08:08 PM   #4 (permalink)
BaByGuRL!!!
jdm slick's Avatar
dude, you just match the color of the wires...it's foolproof!
Of course it's gunna smoke, obviously yellow and red wire does not go together does it?
Sonny: Hey, your MSM intake cam came in...
Me: Dope! Bring it to KINOD, yeah?
Sonny: Maybe, but I'll be late as usual. You got money to bring me?
Me: Money, no. My body for you to splurge on for the night, YES!
jdm slick is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 08:20 PM   #5 (permalink)
Project-G
Risingsun124's Avatar
It sounds like the yellow goes to the constant, not the one that gets power when you turn on your ignition... Otherwise, when you turn off your car, you will lose whatever presets, time, settings, etc. you have set... I never trust wiring guides or what anyone says when it comes to wiring a stereo... Get a test light and check for yourself... It may save you some money and heartache in the long run...
I'm curious what it smells like when it's "about to smoke"...
About the Project-G G-String
The best purchase I made for this car, hands down...including the rotrex.
what?
Risingsun124 is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 11:15 PM   #6 (permalink)
Fran82's Avatar
As Risingsun said, Yellow is constant 12v (battery) for memory. Red goes to switched 12v to actually turn the unit on.
Sounds like you actually have the yellow wire connected correctly, but have the red wire connected to constant also, that's why it won't turn off, unless you hit the radio's power button. Find switched 12v and connect the red wire to that.
Fran82 is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 11:42 PM   #7 (permalink)
Yep I got a test light and it was super easy. I got the CD/DVD/TV/AUX player from my uncle for free but I think the speaker wires on the DVD/CD Player harness is fried. Every thing turns on,the touch screen works but there is no sound =[ The sound works with my other cd player but not with the new one =[. Do you guys think it could be the DVD/CD player itself or the DVD/CD wire harness?
Old 07-27-2009, 11:51 PM   #8 (permalink)
Project-G
What makes you think the harness if fried? I would connect a speaker directly to the speaker leads out of the HU and see if it even works... (Just speaker lead directly to the speaker... No factory plugs and stuff like that...) If it does, then your problem is between your HU and the speakers... If it doesn't, its in the HU itself... Try all the speaker leads and make sure your fader isn't set all the way to the back... If you wired it correctly, I would guess the HU is done... Sorry if I'm stating the obvious, you just never know...
what?
Old 07-28-2009, 12:04 AM   #9 (permalink)
I did connect a speaker directly from the back of the CD/DVD player and nothing happened. I tried each speaker wire and nothing happened. The DVD player played the video the radio stations showed up and the touch screen works. Just no sound.... when i turn the volume up the screen says im turning it up but there is nothing coming out. =[ The head unit has the volume knob on it, so wouldnt the volume display not change if the head unit didnt work?
Old 07-28-2009, 12:58 AM   #10 (permalink)
Project-G
Sounds like it's done...
what?
Old 07-28-2009, 01:13 AM   #11 (permalink)
The whole thing? ^^^
Old 07-28-2009, 01:37 AM   #12 (permalink)
Project-G
Maybe just part of it... The part that lets you hear it...
what?
Old 07-28-2009, 02:15 AM   #13 (permalink)
Haha dam it was a nice one to...
Old 07-28-2009, 11:31 PM   #14 (permalink)
So does anyone else have a second opinion?
Old 07-29-2009, 01:08 PM   #15 (permalink)
theoffspring99us's Avatar
you sure the fast and the furious disk isn't stuck?
I keed I keed
_____
theoffspring99us is offline   Reply With Quote Quick reply to this message
Old 07-29-2009, 01:11 PM   #16 (permalink)
I keed I keed
Thats actually very funny =] hahahhaa
Old 07-30-2009, 10:39 PM   #17 (permalink)
Fran82's Avatar
If it has RCA outs, you can try hooking up an external amp to it. You might have just fried the internal amp.
Old 07-30-2009, 10:41 PM   #18 (permalink)
MadVillain's Avatar
just go back to your 8-track player noob.
MadVillain is offline   Reply With Quote Quick reply to this message
Old 08-09-2009, 12:59 AM   #19 (permalink)
mrryanbaker's Avatar
yellow is the "memory" wire, hooked to constant power so that it doesn't forget your radio stations, presets, etc. Red is power.
mrryanbaker is offline   Reply With Quote Quick reply to this message
Old 08-09-2009, 02:41 PM   #20 (permalink)
'lilRedRide's Avatar
Or it needs an external amp to work.
"The only power any government has is the power to crack down on criminals. Well, when there aren't enough criminals, one makes them. One declares so many things to be a crime that it becomes impossible for men to live without breaking laws."
'lilRedRide is offline   Reply With Quote Quick reply to this message
Old 08-12-2009, 10:51 AM   #21 (permalink)
True. Some dvd HUs don't have a built in amp.
What has this become...
FooSchnickens is offline   Reply With Quote Quick reply to this message
Old 08-12-2009, 02:04 PM   #22 (permalink)
woah
emmi's Avatar
lol evertime i scroll through ur posts, i think its jay posting lol. some cars are not color matched... especially mazdas and nissans. i remember on my friends 240 red was a speaker wire and gray was the acc 12v.
yellow goes to a constant 12v so even plugging it straight to the battery should be fine.
emmi is offline   Reply With Quote Quick reply to this message
Old 08-12-2009, 09:53 PM   #23 (permalink)
^^^ and whenever I see a post by jdm_slick or Kuane im usually falling outta my chair from laughter!!!
Phatmiata is offline   Reply With Quote Quick reply to this message
Old 08-28-2009, 11:38 AM   #24 (permalink)
sncflow's Avatar
i agree with trying an external 4 channel amp. if it has speaker leads from the radio it has to have an internal amp. what make/model is the unit in question? it still may not work if theirs internal damage, but you may get lucky!
sncflow is offline   Reply With Quote Quick reply to this message
Old 09-01-2009, 09:26 AM   #25 (permalink)
It's also possible that the internal amplifier is simply shut off. On certain Headunits (alpine for example) you can turn off the internal amplifier if you're running on the pre-outs. It's designed to save power.
Try finding it in the menu. Otherwise that smell you speak of is likely what's left of your internal amp.
96 Mazda Miata
72 Triumph Spitfire
12 Toyota Tacoma
13 Scion FRS
WRX GC8 is offline   Reply With Quote Quick reply to this message
