| Audio & Electronics Wired up? Everyone's got some sort of stereo or electrical modification or question... let's hear about it here. |
#1 (permalink) |
Look what I found on my door today!
Well it wasn't just luck since I actually paid for it 8) but anyway I'm still excited! ... Now I'm waiting for the XM radio with the TRAFIC control system, the remote control for the steering wheel, the miata harness splitter and then I have to find out how to connect everything and where to place everything! Problems but at least "nice" problems! 8)
Chris Autokonexion Kevlar bumper and fenders 2096lbs FM 2.0L Stroker+GT2560+V-mount+1000cc ID+E85+22psi->335 whp Ford Motorsport Tremec T5z 5 speed transmission 275 Hoosier Koni 3011 coilovers 900 Lbs/inch springs - Daily Driver
#2 (permalink) |
Administrator
Good Lord, what all does it do?!
:shock: |
Tim (Toolman) Allen Owner/Administrator http://TampaBayMiatas.net Administrator http://ClubRoadster.net http://V8Roadsters.com http://V8RSpec.com 1993 Mazda Miata Limited Edition #790 of 1500 Black with Red Interior Coming soon: 1.7l with 45mm Jenvey DCOE IRTBs
#4 (permalink) | |
#5 (permalink) | |
In order to watch the AV source in the AVIC-D2 or to have all the NAVI function while driving you must do the following: 1. Ground the original parking wire (Must Do) 2. There will be a open pin in the wiring harness under the ground wire. You must also ground this pin. I just pulled the wire out from the cellular mute pin and stuck it in the new pin and grounded it. ***This does work! No soldiering necessary. I just installed it into my car!**** |
#6 (permalink) |
Moderator
Good LORD that is HOT - does the face detach for protection? I would be so worried and yet so excited to be in traffic watching Lord of the Rings! Keep us posted on your install.
![]() The Blue Potato / 1995 NA8C Pitcrew #001 / R.S. Aizawa IRTB / RS Watanabe / KG Works www.thebluepotato.net | http://www.thebluepotato.net/blog/ |
#8 (permalink) | |
BACK BY POPULAR DEMAND
A friend of mine put a DVD player in his 240sx and almost killed us both when he was spending more time watching Chappel's Show than the road. |
Dumb Cars I Own:1986.5 Nissan Hardbody (longbed), 1994 Nissan 240sx (Convertible), 1994 Mustang GT Shout-Outs: Hank Chinaski, sonique128, Skinnyroadster, Oops2Low, mk_slayr, Haigog, Kuane. Certified TIG Welder: 304 Stainless / 5052 Aluminum - 3F / 3G - 1/16th - 1/4th inch thick. Keep the Jeep Riding. http://www.youtube.com/watch?v=MCMFt...eature=g-all-u |
#9 (permalink) |
Well as many of you might already know I always want everything to stock - even when it's not. So for this case the problem is how I should install it like that.
No it doesn't fit perfectly in the factory hole... So I had the option of (a)cutting the frame of the NAVI and put it over the console (Pic 1937_2) or to (b)cut the factory console and try to integrate it in. (Pic 1946_2) I followed the second road since the first one would stick out too much (or at least that's what I think). It went pretty good and now I became a bit more ambitious and I want to: ->Find the exact perfect position that I'll install the NAVI (I'm talking about mm here) ->Glue, bondo the Navi frame with the factory console so it would look like one piece! |
#11 (permalink) | |
but if you do your shopping from the best places can do it for about one grand... BTW I just installed everything... |
#14 (permalink) |
bad mother f......
Hey, Max
How do you like it now that youve lived with it for awile? I use a carputer for the miata which can do everything this unit can, but I'm thinking I might go another route for my xB. thanks man |
I'm flipping burgers overtime so I can get the sportmaxxxx of my dreams.
#16 (permalink) | |
Honestly I'm very happy with the AVIC-D2, one of the best things ever is the way it turns on! You see usually the Navi systems need some time to boot, with the Pioneer by the time you put the keys on the music starts (you have volume control etc) and after the some time (about 30sec) the navi is on...but it not annoying because you can still hear the rad/cd etc... The menus are awesome and you can see the acceleration of the car (has two gyro)...In a canyon road (with positive incline) turns I managed to see 1.25g while my brain fluid started to leak from my ear Seriously it's fun! |
#17 (permalink) |
bad mother f......
No I never got OBDII set up. Honestly my setup is nice, but after I add a good nav and OBDII, etc the price is not too much different.
