car wont start - ClubRoadster.net
Old 04-08-2012, 08:36 PM   #1 (permalink)
gl0v3r's Avatar
Default car wont start
hey guys so i recently pulled my dash to do a project then i reinstalled it but once i put everything back in the car wouldnt start i plugged everything back in the way i found it but no luck the car wont even click when i turn the key. i checked fuses just to see if anything blew but no luck. and just a few minute ago when i walked passed it i heard a clicking sound that was coming from the engine bay on the diver side wall couldnt figure out what it was. also the lights dont seem to turn on or pop up but the battery is fine so i'm really confused maybe one of you wirring guru's could help me out with your insight. I am hoping to get this thing running again soon since its my DD and i have to go back to work tomorrow afternoon
gl0v3r is offline   Reply With Quote
Old 04-08-2012, 08:39 PM   #2 (permalink)
SUPER DUPER M0DERAT0R
morr's Avatar
Default Re: car wont start
I know you said the battery is fine, but did you undo the battery and forget to hook it back up?
Originally Posted by Mikexmayhem View Post
Anyone know what size spacers would be needed to get the stock wheels to equal a 0 offset?
morr is offline   Reply With Quote
Old 04-08-2012, 08:45 PM   #3 (permalink)
gl0v3r's Avatar
Yeah I took the battery out and hooked it back up still nothing
Sent from my BlackBerry 9530 using Tapatalk
Old 04-09-2012, 08:55 AM   #4 (permalink)
SuperTuner12010's Avatar
There really isnt much a wiring guru can do to help in this situation.
If the car was running previously, then either something wasnt plugged in or got disconnected. Pull it back off if you have to, make sure both grounds on the sides of the dash are making good contact. Not sure if they could be the culprit in this scenario but grounds are key.
SuperTuner12010 is offline   Reply With Quote
Old 04-09-2012, 09:07 AM   #5 (permalink)
Boostedmx5's Avatar
I was going to say you either incorrectly hooked up sensors, left one or you have an unconnected ground.
Boostedmx5 is offline   Reply With Quote
Old 04-09-2012, 12:10 PM   #6 (permalink)
gl0v3r's Avatar
yeah i'm gonna attempt to pull the dash once more and pray thats the problem and hopefully fix it. you guys wouldnt happen to know the location of the two ground wires super tuner was referring to would you?
Old 04-11-2012, 04:00 PM   #7 (permalink)
Any word on this? I have 2x dashes sitting in front of me, I could get a pic of the 2 grounds if you need.
Old 04-11-2012, 08:15 PM   #8 (permalink)
gl0v3r's Avatar
nothing has work for me so far i found what i think the two grounds are but i believe i have three i suspect the 3rd is my alarm and could be the source of my problem but as far as i can tell everything is plug in the way its suppose to be although i noticed i have 3 harnesses that do not lead to anywhere. but nothing electronic seems to work on the car at the moment so i have a feeling i may also have a dead battery as well
