Fixed the headlight retract problem finally - ClubRoadster.net
Old 04-14-2007, 03:28 PM   #1 (permalink)
Zel
Guest
Posts: n/a
Default Fixed the headlight retract problem finally
I've been cruising all of the miata sites for days and could find a write up with pictures of how to diagnose and repair headlight retract problems. The threads all say the same generic junk.
1. Check dash switch
2. Check it again
3. Check Fuse
4. Check dash switch
5. Check LA12 in engine compartment
6. Check dash switch
and finally in somewhere in the depths of the search results someone said something about a underdash relay.
Guess what I found it, repaired it and wrote it up.
please check it out people and let me know if I missed anything
http://www.cardomain.com/ride/2621593/2
I also posted this over at m.net for those who need help there.
