Timing belt replaced....now crappy accelleration?! - ClubRoadster.net
Old 07-26-2006, 09:02 PM   #1 (permalink)
z00mer's Avatar
Default Timing belt replaced....now crappy accelleration?!
Yesterday, I had a mechanic friend of mine replace a broken timing belt, that snapped in two places on Sat. evening.
Everything seemed o.k., with the exception of the waterpump which was shot... the crank was fine, and all the seals were fine. After replacing the tensioners, waterpump, and timing belt...everything started up just fine. But when it came time to drive my miata home, it took forever to pick up speed. Starting out in first gear, it felt as though you were starting out in third!! On top of that, I started to get the sound of a crushed muffler!! I checked the timing, which was fine. My guess is that the moron had the positions of the cam wheels off.
Do you think this is my problem?
Any useful feedback would be great.
Thanks. :wink:
1990 Silver Stone (STILL....a work in progress)
*sold* (gone but not forgotten)
Now sporting a 2005 Black Onyx 6s!!
http://squintzy.mybrute.com
z00mer is offline   Reply With Quote
Old 07-26-2006, 09:39 PM   #2 (permalink)
brian's Avatar
is it possible cam gears werent on tdc when you put on the belt and tightened everything up? timing good?
brian is online now   Reply With Quote
Old 07-26-2006, 09:48 PM   #3 (permalink)
z00mer's Avatar
Default Re: Timing belt replaced....now crappy accelleration?!
Unfortunately I did'nt do the job, I was at work. But that's my thoughts exactly.
Old 07-26-2006, 11:44 PM   #4 (permalink)
The Vorlon
Mr.Woolery's Avatar
Sounds like the new belt was put on a tooth (or two) off. I'd check the cam gear angles to ensure they're right.
__________________________________________________ __________________
http://www.youtube.com/watch?v=60loeoblu0M
Mr.Woolery is offline   Reply With Quote
Old 07-27-2006, 12:34 AM   #5 (permalink)
MiataRoadster
Guest
Posts: n/a
Or the crank might be 360 degrees off from pistons 1+3 being TDC.
