Kind of Important Question - ClubRoadster.net
Old 05-29-2008, 12:08 PM   #1 (permalink)
Whiskey makes me Frisky
Skinnyroadster's Avatar
Default Kind of Important Question
I was taking out my a/c today and I was going to take the bracket off that holds it to the engine (I even bought a new 50mm 8x1.25 to put in its place), then decided that I'd just leave it on since it was the last thing to take off and I already wrestled the compressor out. Well screwing back on the bolt that goes into the front of the engine the damn thing snaps at the threads. WTF Fail.
How important is this bolt?
Thanks guys.
Originally Posted by aarrowadscom View Post
That's it. That is the post that has killed me.
Forever in my heart.
http://25.media.tumblr.com/tumblr_m2...9ako1_1280.jpg
http://25.media.tumblr.com/tumblr_m7...9ako1_1280.jpg
Skinnyroadster is offline   Reply With Quote
Old 05-29-2008, 03:03 PM   #2 (permalink)
I have a feeling it kinda is necessary. Do you think I can still drive the car till I get it drilled out, tapped and replaced?
Old 05-29-2008, 05:36 PM   #3 (permalink)
bad mother f......
Stealth97's Avatar
Important. it looks like the bolt that goes through the front of the A/C bracket into the oil pump. you will leak with out it.
I'm flipping burgers overtime so I can get the sportmaxxxx of my dreams.
Stealth97 is offline   Reply With Quote
Old 05-29-2008, 05:40 PM   #4 (permalink)
hmm, well I have all of the threads in the hole as you can see. so it shouldnt leak, but I'm going to have to fix that.
Anyone want to extract this in the Orlando area?
I am sure its this bolt (rusman your engine is sexy)
Old 05-29-2008, 10:45 PM   #5 (permalink)
who moved my Pinto?
FordDesignGuru's Avatar
I never new that bolt was supposed to go back in... I've been running for a month with out it!
Damn, did I do something wrong?
1.6 w/ AC removed.
Real live car designer
Ford Design Studios (exterior styling)
FORDDESIGNGURU does not necessarily represent the views or opinions of FoMoCo
FordDesignGuru is offline   Reply With Quote
Old 05-30-2008, 07:08 AM   #6 (permalink)
mazdamitch333's Avatar
haha i ended up with the same thingafter i did my water pump. I had it all put together and looked down and found that same bolt laying there. I stuck it back in a hole that looked good and itfit so luckily it looks like its in the right place.
http://img177.imageshack.us/img177/8689/bannervf0.jpg
I like my cars like I like my women, topless
mazdamitch333 is offline   Reply With Quote
Old 05-30-2008, 08:56 AM   #7 (permalink)
1.6 w/ AC removed.
Okay, well if you have been running for a month with no problems, that gives me a little bit of time to get the damn thing extracted and a new one in.
No oil is leaking from what I can tell, now all I need is one of those little 90 degree drills as its one hell of a tight fit.
Old 06-02-2008, 09:11 PM   #8 (permalink)
who moved my Pinto?
Yep, that stupid bolt hole did LEAK OIL - not good. My son just put the bolt back in moments ago.
I think you put the wrong length bolt back into the block - the shorter bolt goes into the engine - that 50mm bolt held the compressor to the bracket. You may have snapped it off because you bottomed it out(?). But I think you can just leave it in there...
Old 06-02-2008, 10:21 PM   #9 (permalink)
i think your right. i just walk out and looked at my 99 1.8l motor. The bolt is not there but you can see that its not a deep. Max of like 2". Tomorrow I will try and tread a bolt into the whole and give an idea of the length
wildfire0310 is offline   Reply With Quote
Old 06-03-2008, 09:27 AM   #10 (permalink)
yeah the four bolts that hold the compresor to the bracket and the one that goes into the front of the engine all look exactly the same, except the one that goes into the front is like 10mm shorter.
You could see my confusion while laying on my back in the hot florida sun.
It snapped clean at the treads, I am going to take the bracket off either today or tomorrow and see if the threads sits flush or is sunken in a bit, then think of my plan of attack to getting it out.
Old 06-03-2008, 11:08 AM   #11 (permalink)
Well this kinda sucks. its in there somewhere, oh and no leaking oil, yay.
Old 06-04-2008, 10:37 AM   #12 (permalink)
who moved my Pinto?
I am not sure why you would need to pull it out? If enough of the bolt is in there to keep it from leaking then you should be good?
Well, maybe that bolt is supposed to hold the pump together? If that is the case perhaps you should extract/replace it because it will not be doing it's job without a head on it.
Old 06-04-2008, 11:33 AM   #13 (permalink)
I would monitor it for leaks. That bolt was loose on my car, and I got an oil leak. A friend of mine removed it with his A/C delete, and his car shot oil like a spigot.
Though one of the guys I work with removed it on both his cars and doesn't have a leak on either.
Point being, if it doesn't leak, I wouldn't go through the trouble of extracting it.
Ben91 is offline   Reply With Quote
Old 06-04-2008, 12:17 PM   #14 (permalink)
No, I am going to go through the trouble of extracting it. I didnt pull the a/c out half assed so I am not going to leave a half asses stud broken in the block.
Old 06-04-2008, 01:12 PM   #15 (permalink)
Cool, that's probably the right way to go. Good luck with the extraction, Doctor.
Old 06-05-2008, 08:48 PM   #16 (permalink)
who moved my Pinto?
Skinnyroadster,
You have high standards as a mechanic.
You can work on my car anytime!
Old 06-06-2008, 09:31 AM   #17 (permalink)
Originally Posted by FordDesignGuru @ Thu Jun 05, 2008 20:48
Skinnyroadster,
I wouldnt say that, but I try my best....which usually results in some kinda fuck up, like this bolt in question. If I was still up in michigan I'd be down to help out.
Old 06-06-2008, 09:59 AM   #18 (permalink)
silverslider's Avatar
Default Re: Kind of Important Question
does this only hold true of 1.8 or do 1.6 need that bolt also
silverslider is offline   Reply With Quote
Old 06-06-2008, 11:05 AM   #19 (permalink)
FordDesign said that their 1.6L was leaking oil, my 1.8 has no leaks
Old 06-06-2008, 11:12 AM   #20 (permalink)
well the odd part is i took mine out last summer and the only thing that leaks on mine is the front of the oil pan gasket below the crank. one bolt had a little oil on it when removed but has never leaked since.
Old 06-06-2008, 11:24 AM   #21 (permalink)
read the post. I already have a new bolt but half the other is stuck in there
Old 06-07-2008, 07:48 AM   #22 (permalink)
I am pretty sure that that bolt has to be like 45mm to work properly. 50mm will bottom out, and 40mm will not go in far enough. It does go into the oil pump on the engine.
Andrew
wademunkey is offline   Reply With Quote
Old 06-07-2008, 08:08 AM   #23 (permalink)
no its 50mm
Old 06-07-2008, 06:10 PM   #24 (permalink)
who moved my Pinto?
OK, my son confesses that the bolt still sticks out about 10mm. He seated it tight, but was careful not to break it off .
I think I am going to have him put a stack of washers on it (?)
Old 06-07-2008, 07:39 PM   #25 (permalink)
Speed Racer
XCLR8TN's Avatar
This is getting interesting, subscribed.
_Jess_
1991 White Mazda Miata DD
1991 BRG Mazda Miata
LS6 swap coming soon (getting close!)
http://clubroadster.net/vb_forum/89-roadster-projects/33687-91-brg-ls6-build.html
XCLR8TN is offline   Reply With Quote
Old 06-07-2008, 10:51 PM   #26 (permalink)
there should be five bolts that look the same, four that hold the compressor to the bracket (the long ones) and one that goes into the front of the engine...this is the shorter one, looks to be around 10mm shorter.
maybe I'll take some pics of the bolts tomorrow
