Will i throw a CEL on OBD1 if I remove the charcoal canister? - ClubRoadster.net
Old 08-29-2006, 07:33 PM   #1 (permalink)
Caldera's Avatar
Default Will i throw a CEL on OBD1 if I remove the charcoal canister?
I'm sick of the clutter, and would love to get rid of this piece... but when i did it on the Neon, i threw a CEL for it.
Does the OBD1 computer pitch a fit if you remove the charcoal canister? Worst case scenario, i'll bracket a neon one in somewhere hidden (it's smaller and rectangular), but i'd really prefer to remove it entirely since I never saw it make an efficiency difference on the other car.
-Matt
'05 Elise, '99 Neon. No more Miata... for now.
Caldera is offline   Reply With Quote
Old 08-29-2006, 11:46 PM   #2 (permalink)
LUV2TURN's Avatar
Default Re: Will i throw a CEL on OBD1 if I remove the charcoal canister?
Since when is a Neon's charcoal canister rectangular???? Mine was a big can, probably bigger than the Miata's. My Neon was '96, maybe they changed 'em?
I'm going to start "shitted."
My MX6 is shitted.
1997 C-package. Shitted.
LUV2TURN is offline   Reply With Quote
Old 08-30-2006, 12:15 AM   #3 (permalink)
Caldera's Avatar
They did. The early ones (95-97) were round. In 98-99, they moved to a rectangular one that sits a little more tidily against the inside of that inner-bumper area up on the front passenger corner. I'm pretty sure it's smaller than the Miata's but if nothing else it'll fit better flush against something (maybe up in the fuel filter area?) than that big round one does.
-Matt
Old 08-30-2006, 08:58 AM   #4 (permalink)
Moderator
the blue potato's Avatar
Getting back to your question - I do not think so. I removed mine (I have 1995, non-OBDII) and no CEL's. Again, for a Miata.
The Blue Potato / 1995 NA8C Pitcrew #001 / R.S. Aizawa IRTB / RS Watanabe / KG Works
www.thebluepotato.net | http://www.thebluepotato.net/blog/
the blue potato is offline   Reply With Quote
Old 08-30-2006, 11:09 AM   #5 (permalink)
Caldera's Avatar
I thought 1995 was the first year od OBD2... good to know!
How long has it been out?
-Matt
Old 08-30-2006, 05:56 PM   #6 (permalink)
Moderator
OBDII for NA = 1996-1997
Been out now for 2 years - but I have a piggy back ECU as well - keep that in mind.
Old 08-30-2006, 06:30 PM   #7 (permalink)
Caldera's Avatar
Hrm. If it's just piggyback, then i'd expect a CEL if you were going to throw one.
This is just to hold me over until the megasquirt goes in anyhow.
-Matt
Old 08-31-2006, 01:21 AM   #8 (permalink)
Caldera's Avatar
Okay... canister is gone, ancilary bracketry, etc is gone as well... I unplugged the purge solenoid, and tucked the wire away.
Now the question, I now have that metal line sticking straight up by the alt... is it okay here or can te purged fuel run into issues from sparks at the alt? Blue, what'd you do with yours?
-Matt
Old 08-31-2006, 08:22 AM   #9 (permalink)
Moderator
That is simply your vent line from your fuel tank. I filtered (not capped) mine off with a small R/C (radio control) car filter cover unit - you can also look for small airfilter to use from automotoive shop.
You can see mine in lower right hand corner of this pic (foam covered):
Old 08-31-2006, 03:48 PM   #10 (permalink)
CR.net Old Geezer
NA3Turbo's Avatar
^so pretty. i took the metal line out all the way to the back of the car.
NA3Turbo is offline   Reply With Quote
Old 09-14-2006, 07:56 PM   #11 (permalink)
i capped mine for a few months now with no problems. (1990) i also removed the sensor and wiring...
Be yourself, and Rock it Loud!
BAM! is offline   Reply With Quote
Old 09-14-2006, 07:59 PM   #12 (permalink)
Caldera's Avatar
Mine's been open for 2-3 weeks now, I rerouted the line forward past the radiator just in case, i didn't want vapors near the sparks in the alternator.
-Matt
Old 09-15-2006, 10:12 PM   #13 (permalink)
90_mx's Avatar
Notice any smell of fuel?
90_mx is offline   Reply With Quote
Old 09-16-2006, 11:00 AM   #14 (permalink)
Caldera's Avatar
Only on one occasion, RIGHT after I started the car and blipped the throttle. Before/after/since? Nothing.
-Matt
Old 11-14-2006, 08:09 AM   #15 (permalink)
Speed Racer
XCLR8TN's Avatar
Does anyone here have emissions testing? I can't remember if they popped the hood or not... wonder if they wouldn't pass me if I took the canister out.
_Jess_
1991 White Mazda Miata DD
1991 BRG Mazda Miata
LS6 swap coming soon (getting close!)
http://clubroadster.net/vb_forum/89-roadster-projects/33687-91-brg-ls6-build.html
XCLR8TN is offline   Reply With Quote
Old 11-28-2006, 12:08 PM   #16 (permalink)
I too would like to remove that ugly black canister. In fact I wanna remove its whole system. Would this throw a code. ('94)
I read, not here, that if I block the egr port/valve in the manifold that under boost it could start boosting the manifold is this true?
I live in florida and we don't have emissons here, I do not run with a cat to improve exhaust flow so the egr system is only there to annoy me with its occupied space.
mr.pot is offline   Reply With Quote
Old 11-28-2006, 12:32 PM   #17 (permalink)
hopefully the manifold is pressurized under boost.
Braineack is offline   Reply With Quote
Old 11-28-2006, 01:52 PM   #18 (permalink)
Yeah I realize it was stupid and I should stick to what I know/don't know, see below. LOL
From my basic knowledge there is flow from somewheres to the canister back to the bottom of the intake manifold, whatever that is called, then a flow from there to the intake tube.
If i just start removing tubes and blocking any 'holes' that occur will I get some unwanted results should have been my question, and now is ?
