tranny wont shift in to gear and its not the clutch master or slave - ClubRoadster.net
Old 11-06-2006, 09:15 PM   #1 (permalink)
xNARoadstarx's Avatar
Default tranny wont shift in to gear and its not the clutch master or slave
heres the story i was driving one morning and I stepped on the clutch to shift in to gear and felt the clutch pop/snap kinda feeling. I thought it might be a bad master C or the slave and have just replaced them. I bleed them good and it wont go in to gear when the engine is running. My next guess would be the tranny shift lever or something else inside. I only have time on the weekends and its not very much to work on it. Just wonering if anyone has had this problem or know what it could be
xNARoadstarx is offline   Reply With Quote
Old 11-06-2006, 09:17 PM   #2 (permalink)
Administrator
timallen's Avatar
Default Re: tranny wont shift in to gear and its not the clutch master or slave
It may be possible that your clutch fork is not engaging the release bearing, but I would check the bottom end of your shift lever first and make sure the urethane ring is not in little pieces in the turret.
Tim (Toolman) Allen
Owner/Administrator
http://TampaBayMiatas.net
Administrator
http://ClubRoadster.net
http://V8Roadsters.com
http://V8RSpec.com
1993 Mazda Miata Limited Edition #790 of 1500
Black with Red Interior
Coming soon: 1.7l with 45mm Jenvey DCOE IRTBs
timallen is offline   Reply With Quote
Old 11-10-2006, 07:06 PM   #3 (permalink)
^^^ do that first.
Is the weather cold? My car does that when it is cold. I have to slam it into gear sometimes.
Does the clutch feel like it is slipping?
Miazda318 is offline   Reply With Quote
