engine damper - ClubRoadster.net
Old 11-15-2006, 11:20 PM   #1 (permalink)
Default engine damper
anyone installed an engine damper? wondering how does it affect the feel of the car? I know it doesn't make the car faster, but if it makes it smoother i wouldn't mind picking one up.
geromichi is offline   Reply With Quote
Old 11-15-2006, 11:35 PM   #2 (permalink)
Moderator
the blue potato's Avatar
Default Re: engine damper
Does nothing much for HP increase per se - spend your $$ elsewhere, but there is an acceleration diffference based on the damper preventing or dampening the movement of the engine under heavy RPM's.
The Blue Potato / 1995 NA8C Pitcrew #001 / R.S. Aizawa IRTB / RS Watanabe / KG Works
www.thebluepotato.net | http://www.thebluepotato.net/blog/
the blue potato is offline   Reply With Quote
Old 11-15-2006, 11:39 PM   #3 (permalink)
freedomgli's Avatar
Jimmy said it helped a lot on his car to reduce rocking even with his Mazdaspeed motor mounts. I don't have one but that doesn't stop me from giving an opinion on the subject. I imagine it helps make upshifts feel a little more crisp and makes the throttle response feel a smidgen sharper. Only you can determine how sensitive you are to this. I wouldn't use an engine damper as a substitute for replacing worn out or damaged motor mounts.
Old 11-16-2006, 01:22 AM   #4 (permalink)
snig's Avatar
I have the tuckin99 damper on my MSM. Shifting has become alot smoother.
snig is offline   Reply With Quote
Old 11-16-2006, 02:33 AM   #5 (permalink)
RusMan's Avatar
where did you get it? Got any pics?
RusMan is offline   Reply With Quote
Old 11-16-2006, 06:24 AM   #6 (permalink)
Sponsor
4 Throttle Tuning's Avatar
Freedomgli is right if you have worn motor mounts I would replace those first. Taka @ A-RF always uses them on his cars so I decided to start carrying them and they do work and will stay on my car. My engine use to rock like mad on start up with my IRTB's until it warmed up. Our Engine Damper is the same as all of your JDM shops carry. We carry them in Red or Blue.
Jimmy
FujiRacing
File Type: jpg fujiracing_engine_torque_damper_116.jpg (310.5 KB, 71 views)
4 Throttle Tuning is offline   Reply With Quote
Old 11-16-2006, 07:54 AM   #7 (permalink)
retrorocket's Avatar
Peter
What type of damper is that on your car ?
I am looking to get one for my IRTB setup but I am also using my cusco front brace so I have fitment issues with the tuckin99/A-RF type !
retrorocket is offline   Reply With Quote
Old 11-16-2006, 09:09 AM   #8 (permalink)
Moderator
Peter
Ahhhhh-soooo - this was given to me by Team Aizawa and I modified the bracket a bit for my 1.8. I am sure it is a cobbled together motorcycle unit with shop parts, etc.
I need to find out if mind is adjustible or not - as it is VERY siff.
Old 11-16-2006, 11:10 AM   #9 (permalink)
:!: Other than looking cool as hell, I would say don't waste the $$$$$$. I good set of motor mounts would do the trick. But it's all in what you are going for........Peter you still haven't figured out how to adjust that thing??? Whats up with that?
frosty115 is offline   Reply With Quote
Old 11-16-2006, 11:38 AM   #10 (permalink)
jdmwackness's Avatar
you can just make something similar for a few dollars at a hardware store
*hint hint*
someone put together something like this for cheap as a kit so a lazy person like me does not have to go to the hardware store
Grip Gambler
Chicago Street Drift Team
Est. 2003
http://philstarsays.wordpress.com
jdmwackness is offline   Reply With Quote
Old 11-16-2006, 03:34 PM   #11 (permalink)
freedomgli's Avatar
Yes but a hardware store bracket will remove nearly all compliance which could have unintended consequences. A damper will dampen the motion but not necessarily prevent motion. It really depends on how stiff the valving is. They do look cool as hell, though.
Old 11-16-2006, 04:44 PM   #12 (permalink)
Moderator
And what Kyle says is true - if you do not dampen you will crack the engine block - I have seen this with badly mounted S/C blowers - that area where the engine is mounted need to have care, etc. But you can buy the motorcycle steering dampers cheaply enough on ebay - and then find your own hardware.
Old 11-16-2006, 04:51 PM   #13 (permalink)
Caldera's Avatar
Hrm.
Ya know... the firstgen Neons use one of those as a rear engine mount... it's subtle, it's black, Mopar Performance makes a cheap, upgraded unit.
Hrm. I think i'm gonna find me a bobble strut in my crap at home and see if I can make a damper! I just wasn't sure how I wanted to bracket it to clear my strut brace until now.
-Matt
'05 Elise, '99 Neon. No more Miata... for now.
Caldera is offline   Reply With Quote
Old 11-16-2006, 05:31 PM   #14 (permalink)
freedomgli's Avatar
The FujiRacing Engine Damper is only $89. For those who want the ultimate in engine bay bling you could adopt an Öhlins steering damper to fit.
Old 11-16-2006, 06:20 PM   #15 (permalink)
Caldera's Avatar
Ok... the Ohlins is hotness.
... 89.00? Hrm. Maybe after I figure out how much of a difference it makes with a 5.00 prototype.
-Matt
Old 11-17-2006, 06:54 PM   #16 (permalink)
LUV2TURN's Avatar
Originally Posted by Caldera @ Thu Nov 16, 2006 6:51 pm
Hrm.
Well, I don't know if you could really call it an engine mount, per se...It's more of an anti-torque strut, can't remember exactly what the dealer called them....on neons.org it's always just 'bobble strut'
I replaced my shot one with the booger unit...combined with deyeme flex/firm mounts, my Neon was one shaky car
I'm going to start "shitted."
My MX6 is shitted.
1997 C-package. Shitted.
LUV2TURN is offline   Reply With Quote
Old 11-18-2006, 03:31 AM   #17 (permalink)
RusMan's Avatar
Is it a real damper? I know the ebay ones just look like dampers but if you take them appart they're just filled with some hard rubber.
Old 11-18-2006, 04:32 AM   #18 (permalink)
Caldera's Avatar
Originally Posted by LUV2TURN @ Fri Nov 17, 2006 4:54 pm
Hrm.
Gah, what do they call them, I think maybe it's just torque-damping strut or some such. Strangely, I actually went away from solid mounts. My ACR is just one big echo chamber, my final mount setup has been a Quickor bobble (the one now being sold by Vitor) and stock mounts the rest of the way around... keep the mounts in good shape, and wheelhop wasn't a problem. I think that was mostly because I lost the ability to romp the throttle sometime after I added the first 2.4l and had to learn to modulate throttle.
But yeah, I've got a stock unit, and I think an MP one somwhere... it should make for a nice compromise between breaking things, and having nothing. If it doesn't work, i'm out a whopping however much the scrap steel and electricity to run the plasma cutter cost me.
-Matt
Old 11-18-2006, 11:00 AM   #19 (permalink)
Matt [exz3owner]'s Avatar
peter-
how do you explain the change in acceleration? The engine damper at most prevents 20 degrees of engine rotation per gear, which equates to less than the firing of 2 cylinders for a full run through 5 gears.
Why do you think limiting this movement changes acceleration?
2008 Redline TimeAttack! Grand Champion
[img]hhttp://photos-g.ak.facebook.com/photos-ak-snc1/v271/25/27/561716982/n561716982_1086838_2140.jpg[/img]
Matt [exz3owner] is offline   Reply With Quote
Old 11-19-2006, 03:32 PM   #20 (permalink)
iWeasel410's Avatar
Wanna stiffen those motor mounts on the cheap? Check out this article I found at DSMtuners
http://www.dsmtuners.com/forums/showthread.php?t=205132
talk about ghetto, but I don't see why it won't work :-P
iWeasel410 is offline   Reply With Quote
Old 12-20-2006, 05:07 PM   #21 (permalink)
raen419's Avatar
Filling motor mounts with polyurethane is nothing new. 240sx guys have been doing it for years. Makes the car vibrate a good bit at idle, but beyond that its pretty nice. I did it to my S13 a few years ago. I liked it, but if you do a lot of stop/go driving, it may get on your nerves.
Man, you know what reminds me of a 240sx? The 1984 Cadillac Eldorado. - VitaminT
raen419 is offline   Reply With Quote
Old 12-20-2006, 05:42 PM   #22 (permalink)
engine dampers are usually mounted on the head, right? most drifters like to use them too i assume. i don't find this item more attractive over some nice motor mounts because of where its positioned and its function. it stresses the head and what keeps it down would obviously be your head studs. thats one reason i think fabbing one up and placing it whereever it allows u to is a bad idea. it may be useful on drift cars to dampen the motor's torque twist when they abuse their cars and clutch kick...but i only assume over long periods of useage even without abusive drifting habits will turn up negative results in the long run.
MAX SPEED-shift_downHiGhWaYsT@R
renesisdrms is offline   Reply With Quote
Old 12-20-2006, 05:59 PM   #23 (permalink)
i prefer stiffer motor mounts. but even that has its shortcomings. my dash would vibrate on 1st gear take off. and it changes the engine's natural harmonic balancing. even small engine mods that seem harmless actually has its flaws. one just don't know because we don't have the research equipment to delicately tune compared to the factory.
another way to look at this example is: stiff competetion suspension puts more stress on the body, right? your suspenson won't move, but there'll be more body twisting! somethings gotta compensate for it. i guess its what one's willing to deal with. i'm merely suggesting one should consider thoroughly before buying parts. having unneccessary parts will also bring in the unwanted problems with it. not to mention the more items to disassemble when u actually gotta fix something.
just my opinion. only wanted to give something one can consider.
Old 12-20-2006, 06:49 PM   #24 (permalink)
Caldera's Avatar
3M Quick-Cure window weld works better. That said, there's no voids in the Miata engine mounts to fill!
-Matt
Old 12-22-2006, 12:39 PM   #25 (permalink)
Max_Power's Avatar
Today I started a bit aggressively in the traffic light (3K rpm) and the engine started to vibrate and hitting the hood from the SC side...as a result the whole hood was vibrating!!!
In the past I was getting only wheel hop, but now with the stiffer spring I'm getting move engine vibration!
BTW I DO HAVE THE MS ENGINE MOUNTS
So I think I need a damper, do you know if there is anything out there that will fit with a JRSC?
Chris
Old 12-25-2006, 02:21 AM   #26 (permalink)
slydin miata 619's Avatar
i've been thinking if this precedure actually works?
slydin miata 619 is offline   Reply With Quote
Old 12-25-2006, 11:31 AM   #27 (permalink)
Camtheman's Avatar
In order to fit the damper on a supercharger you will def. need one that mounts in front of the suspension tower. The 2 common ones will not fit (BR and weapon r) You might have luck modding the brackets on those, they place the damper behind the tower, you need one than is a straight shot over from the engine hoist hook/loop.
Camtheman is offline   Reply With Quote
Old 01-02-2007, 02:15 AM   #28 (permalink)
kotomile's Avatar
When I was NA and could spare the room on the driver's side I used a solid "homedepot" turnbuckle brace, worked absolutely fantastic. Now I need to figure out how to make it work with the Turbo.
'93 Greddy turbo
247/217 uncorrected @ 14 psi
http://img.photobucket.com/albums/v6...Rdotnetsig.jpg
kotomile is offline   Reply With Quote
Old 01-03-2007, 05:08 AM   #29 (permalink)
MiataRoadster
Guest
Posts: n/a
Ingalls Stiffy:
http://www.ingallseng.com/parts/ETD/ETD-Specs.htm
Old 01-03-2007, 04:01 PM   #30 (permalink)
raen419's Avatar
Bill, I want one.
When will those be available?
