MSM engine in 91 NA, I Have questions. - ClubRoadster.net
Old 08-26-2010, 02:33 AM   #1 (permalink)
91Miata23's Avatar
Default MSM engine in 91 NA, I Have questions.
Ok so i was looking around and had the idea, maybe I should put a Newer 1.8 out of a 04-05 Mazdaspeed in my car.
I DID search on here a bit and a little on m.net but i still have a few questions.
1.DO you guys think its a good idea
2.To do the swap was thinking of basically swapping everything over from a wrecked MSM(rear ended) engine+trans, full wire harness, cluster. (maybe even dash)
3.Could I still retain my 1.6 rear end. Or would it just be best to swap the rear of the MSM in there?
I'm really thinking of going this route, the best miata engine (in my opinion) in a classic red Na just sounds a bit awesome to me. Plus turbo power
Don't flame me on this
91Miata23 is offline   Reply With Quote
Old 08-26-2010, 03:00 AM   #2 (permalink)
Migit109's Avatar
Default Re: MSM engine in 91 NA, I Have questions.
most of the time it wouldnt be worth it, but since you have a whole msm id say maybe depending on if you think its worth it to get minimal gains over a stock nb bp
when you could just get a nb bp turbo it (to your liking) instead of swapping out a whole wiring harness and being stuck with a meh turbo until you replace the exhaust manifold and downpipe
if your strapped for cash and have plenty of spare time and have your heart set on it, id say yes. Otherwise id say get a nb bp motor and turbo that and save a lot of time.
just my 2 cents
[SIGPIC][/SIGPIC]
"I will fuck the old out of you! Right now, all night long!"
-The Incresingly Poor Decisions Of Todd Margaret
The Anti-Style Bar Empire - Saving Lives since 2010
Migit109 is offline   Reply With Quote
Old 08-26-2010, 03:00 AM   #3 (permalink)
Down with the brown.
Fresh NB's Avatar
Interested to here people's feedback.
Originally Posted by psulja View Post
At first glance I thought it was Breezy and then realized the wheels and tires actually kinda fit.
Fresh NB is online now   Reply With Quote
Old 08-26-2010, 03:01 AM   #4 (permalink)
Esteemed Member
DazedAndConfused's Avatar
I've seen it done before with dash and everything and it looked clean as hell. I would swap the rear end for a torsen, but not a MSM one. They are not as easy to come by as earlier model 1.8 torsens.
DazedAndConfused is offline   Reply With Quote
Old 08-26-2010, 03:15 AM   #5 (permalink)
91Miata23's Avatar
I basically have the MSM for the engine+trans+dash+harness+ecu+exhaust (can get these)
I don't want to do a turbo build myself cause I'm just lazy.
Plus, I'm not this power hungry guy I'm fine with stock Na 1.6 power all 70hp my car probably had when it was running.
But I drove a MSM and I just fell in love with that engine in stock form. I'm a sucker for OEM+ as well.
Old 08-26-2010, 03:23 AM   #6 (permalink)
Function > Form
saedrin's Avatar
Get the drivetrain, swap the valve cover for the normal NB 1.8 valve cover so you can use your OEM ignition, and shit will bolt up like a standard NB 1.8 swap. Add megasquirt, tune to flavor, and enjoy.
-Zack
Turbo'd/r-comp'd NB1.
Build Thread
E39 M5, Daily.
The Beast
saedrin is offline   Reply With Quote
Old 08-26-2010, 03:46 AM   #7 (permalink)
Migit109's Avatar
ah ah ah... cant do that its a different bolt pattern for the valve cover on a msm than a nb bp
[SIGPIC][/SIGPIC]
Old 08-26-2010, 04:32 AM   #8 (permalink)
Function > Form
saedrin's Avatar
Are you sure? AFAIK the head is identical to the BP4W in the 99-00 minus the valve cover and COPs. It doesn't really matter though, you should be able to use stock ignition wires on the MSM cover anyways. Or just wire in the MSM COPs for megasquirt.
-Zack
Build Thread
E39 M5, Daily.
The Beast
Old 08-26-2010, 04:47 AM   #9 (permalink)
Migit109's Avatar
i think if you do any swap its a good time for a trim on the wire harness and delete a buncha shit
[SIGPIC][/SIGPIC]
Old 08-26-2010, 05:35 AM   #10 (permalink)
RustyNWeathered's Avatar
eh..I think the turbo system on the MSM is junk..
I wanna rock you like the 80s
RustyNWeathered is offline   Reply With Quote
Old 08-26-2010, 05:35 AM   #11 (permalink)
sexy ass cars tho...would love to have one...just wouldnt do that swap
Old 08-26-2010, 05:49 AM   #12 (permalink)
Miata Master
sideshow's Avatar
http://miata.net/motm/2008/brandt.html
sideshow is offline   Reply With Quote
Old 08-26-2010, 06:07 AM   #13 (permalink)
Function > Form
saedrin's Avatar
Bam. MSM valve cover and NA ignition.
-Zack
Build Thread
E39 M5, Daily.
The Beast
Old 08-26-2010, 04:41 PM   #14 (permalink)
innocent_blue's Avatar
do it. it's worth it
But there's a cool knowingness to the dialogue between man and machine that wasn't there with the original Miata: You expect this new MX-5 to be good--and aren't surprised when it is.
innocent_blue is offline   Reply With Quote
Old 08-26-2010, 04:54 PM   #15 (permalink)
Migit109's Avatar
err what?
its a msm engine in a NA... dont you see that intake going to the turbo and the piping going down from the intake manifold?
[SIGPIC][/SIGPIC]
Old 08-26-2010, 05:01 PM   #16 (permalink)
Function > Form
saedrin's Avatar
err what?
What are you confused about?
It's an MSM engine, with an MSM valve cover, using the standard NA ignition and not the MSM coil on plugs.
-Zack
Build Thread
E39 M5, Daily.
The Beast
Old 08-26-2010, 05:06 PM   #17 (permalink)
Migit109's Avatar
thats my retarded fault, i miss read it completely
[SIGPIC][/SIGPIC]
Old 08-26-2010, 05:07 PM   #18 (permalink)
Function > Form
saedrin's Avatar
-Zack
Build Thread
E39 M5, Daily.
The Beast
Old 08-26-2010, 05:07 PM   #19 (permalink)
Old 08-26-2010, 05:14 PM   #20 (permalink)
Going up the Country
Verwah's Avatar
I know a guy who did it. He's on mazda-speed.com as '95MSM. He can probably give you tips. I know it wasn't easy.
Verwah is offline   Reply With Quote
Old 08-26-2010, 08:09 PM   #21 (permalink)
mini_FD's Avatar
If you do the swap, you need the mobilizer and ignition set so the motor can start. It's a fail safe system that i heard some can bypass. Then again, you said your ignition is going to be from your motor.
My baby by rocketeerbandit, on Flickr
MazdaSpeed/Garage Vary/Mishimoto/Autokonexion/AEM/ACT Stage3 6Puck/4.1torsen/Tein Flex/Racing Beat/Nardi 330mm/ Ryoku Rob/Fidanza/GarageStar/RS*R/JacksonRacingSwaybar
mini_FD is offline   Reply With Quote
Old 08-26-2010, 08:24 PM   #22 (permalink)
91Miata23's Avatar
No, Ill have the ignition from the MSM
Old 08-26-2010, 08:36 PM   #23 (permalink)
Function > Form
saedrin's Avatar
Please, don't do that. Use the OEM NA ignition, the NA harness, and run a standalone. It's the easiest way. The OEM MSM ecu is garbage and you'd have to swap the entire wiring harnesses to use it, which is a pain in the ass.
Unless you're saying you're using the MSM coils with a standalone, in which case it's fine.
-Zack
Build Thread
E39 M5, Daily.
The Beast
Old 08-26-2010, 08:43 PM   #24 (permalink)
91Miata23's Avatar
Ok, Ill explain again.
Basically I have a full MSM with a wrecked rear end and EVERYTHING is still intact. all i have to do is switch it ALL over to the na
Old 08-26-2010, 09:03 PM   #25 (permalink)
Function > Form
saedrin's Avatar
Right, I'm telling you the OEM MSM ecu is a pile of shit. In order to use the OEM ecu, you'd have to switch the entire wiring harness over (immobilizer, engine sensors, ignition, etc). It's much easier, and better in the long run, to run a megasquirt. They're cheap, you don't have to swap any harness over, many people can tune them, and you'll never be hindered by lean-tip in, TPS problems, crappy running conditions, etc like you will with the OEM MSM. There is a reason it is highly recommended to replace the MSM ecu.
-Zack
Build Thread
E39 M5, Daily.
The Beast
Old 08-26-2010, 09:43 PM   #26 (permalink)
91Miata23's Avatar
But, I do plan on doing the full harness conversion. So i can tuck some wires blah blah. And thanks for the heads up on the MS
Old 08-28-2010, 01:46 PM   #27 (permalink)
MSMjohn's Avatar
To go through all that trouble for a MSM engine stock is not worth it. The MSM needs to be modified to be worth it but when you begin to mod it you begin to run into a bunch of problems.
2004 Mazdaspeed mx5 | stock temperature gauge linearization mod | FM intake | FM downpipe | manual boost controller | Porterfield R4S brake pads | Filtermag: oil filter magnet | Stewart Warner 0-15 psi boost gauge: pillar mounted | Devils Own progressive water methanol injection kit @ 14.5 lbs boost | Dunlop DIREZZA SPORT Z1 star spec tires 215/40/17 treadwear 200
MSMjohn is offline   Reply With Quote
Old 08-28-2010, 02:31 PM   #28 (permalink)
Migit109's Avatar
from what i can tell making 220hp is fine for him and thats just injectors, new intercooler, boost controller, and exhaust right?
[SIGPIC][/SIGPIC]
Old 08-28-2010, 06:30 PM   #29 (permalink)
Function > Form
saedrin's Avatar
ECU.
-Zack
Build Thread
E39 M5, Daily.
The Beast
Old 08-29-2010, 09:48 AM   #30 (permalink)
MSMjohn's Avatar
You are correct the OEM MSM ecu is a pile of junk.
