Mazdaspeed OEM Clutch - ClubRoadster.net
Old 08-29-2010, 09:50 PM   #1 (permalink)
Herpity Derpity
Mazduh's Avatar
Default Mazdaspeed OEM Clutch
So I recently bought my msm. I've only put maybe 1500 miles on it since owning. I'm noticing some clutch chatter in 2nd and 3rd at low rpm. I'm fairly sure its still the stock clutch. So anyone who knows MSM's, whats the oem clutch lifespan? I'm just at 49k btw.
Build #361 2005 Mica Black MSM:
www.FukYeaMiatas.me
I like how dick cums with its own sawce.
Mazduh is online now   Reply With Quote
Old 08-29-2010, 10:08 PM   #2 (permalink)
<3's ClubRoadster.
JerseyKid's Avatar
Default Re: Mazdaspeed OEM Clutch
A clutchs life all depends on the driver, im on almost 80K on mine and stock clutch is holding up fine.
Chatter doesn't mean the clutch it bad, a clutch is bad when at WOT it slips.
JerseyKid is offline   Reply With Quote
Old 08-29-2010, 10:15 PM   #3 (permalink)
Herpity Derpity
Mazduh's Avatar
O I know the clutch isn't bad. The chatter just has me a little worried is all. I'm just curious if I should know anything.
www.FukYeaMiatas.me
Old 08-30-2010, 01:07 PM   #4 (permalink)
I <3 CR
Sin-Tek's Avatar
mine does it. It has since around 25k. My 2000 did it too.
Sin-Tek is offline   Reply With Quote
Old 08-30-2010, 01:13 PM   #5 (permalink)
Going up the Country
Verwah's Avatar
Mine has a little shudder occationally when in first from a halt. I've got 22,000 miles on a basically babied car. The last 4,000 miles have a few track days and hard street pulls on the clutch, but its in very good shape. The MSM stock clutch is a robust Exedy unit, and it should last the better part of 100,000 miles on stock power. If the car is making 250hp, it will still hold, but usually about half the lifespan is expected. Especially if you are using that power frequently.
Verwah is offline   Reply With Quote
