car will only run if i keep spraying starter fluid through intake - ClubRoadster.net
Old 09-26-2010, 11:05 PM   #1 (permalink)
miataongt3s's Avatar
Default car will only run if i keep spraying starter fluid through intake
ok i recently did an engine swap on my miata and when i went to go fire it up it wouldnt so i sprayed starter fluid and she started right up, it will continue running as long as i keep spraying starter fluid through the intake , i losened the injectors to see if there was no fuel coming in but there is fuel coming in , i thouhht it was bad gas and it wasnt . has someone has a similar problem ? does anyone know the solution?
thanks kevin
miataongt3s is offline   Reply With Quote Quick reply to this message
Old 09-26-2010, 11:06 PM   #2 (permalink)
HighwayStaR*'s Avatar
Default Re: car will only run if i keep spraying starter fluid through intake
Interesting.....
Power Of The NOVA FORCE!!! Nova Corps TD04 Turbo kit on a stock 1.6,5psi,Begi Downpipe,Mishimoto radiator and fans, Flyin miata exhaust,Greddy turbo timer,Megan Ez Coilovers,HDHCHDDDHHDHDHC Rollbar
HighwayStaR* is offline   Reply With Quote Quick reply to this message
Old 09-26-2010, 11:08 PM   #3 (permalink)
Originally Posted by HighwayStaR* View Post
Interesting.....
i had a suspition of it being the coil pack and it was , mine was firing just fine .
Old 09-26-2010, 11:09 PM   #4 (permalink)
Supporting Member #5522
j-radvw's Avatar
i dont know how to fix your problem. but if you use a lot of starter fluid you will put holes in your pistions. and what kind of engine swap did u do? and cheack you mass air flow sensor.
j-radvw is offline   Reply With Quote Quick reply to this message
Old 09-26-2010, 11:10 PM   #5 (permalink)
So it was your coil pack?
Old 09-26-2010, 11:17 PM   #6 (permalink)
Sequence Number 1280
terry pham's Avatar
What does coil packs have to do with fueling issues? Am I missing something here?
terry pham is offline   Reply With Quote Quick reply to this message
Old 09-26-2010, 11:34 PM   #7 (permalink)
We need more info. Is it only spraying fuel out the injectors when you are turning the engine over? I had this same problem and it turned out being my air flow meter. With the miatas, the fuel pump will come on when you turn the key to the start position. Once the engine starts and you release the key, it's the airflow meters job to keep the fuel pump running. The reason being, is because inside the airflow meter is a little contact point that has to be touching for the fuel pump to continue running. My flapper valve inside my airflow meter was stuck shut, and because it wasn't opening, it wasn't allowing those 2 contacts to touch and keep the fuel pump going. So mine would start up and then pretty much immediately die.
TopNotch is offline   Reply With Quote Quick reply to this message
