HELP ASAP! I need TORQUE SPECS FOR CRANK AND ROD CAPS! 1.8 - ClubRoadster.net
Old 01-06-2007, 09:00 PM   #1 (permalink)
Default HELP ASAP! I need TORQUE SPECS FOR CRANK AND ROD CAPS! 1.8
So we are building my bottom end as I Type this and well I thought I had the specs with my alldata but i dont, So I need the Torque Specs for the ROD and MAIN bearing caps!
Thanks!!!!
This is in a 1.8 2000 4W
SpyderWizard is offline   Reply With Quote
Old 01-06-2007, 10:27 PM   #2 (permalink)
For future reference for anyone else ever hunting:
Main Cap Spec: 54-58 ftlbs
Rod cap spec: 35-37 ftlbs
Old 01-06-2007, 11:29 PM   #3 (permalink)
MiataRoadster
Guest
Posts: n/a
Default Re: HELP ASAP! I need TORQUE SPECS FOR CRANK AND ROD CAPS! 1.8
Are those for OEM bolts or ARP studs?
Old 01-07-2007, 12:55 AM   #4 (permalink)
Ninja Messiah
kung fu jesus's Avatar
yah, if they are ARP, you need to use different torque values.
I ♣ baby seals.
kung fu jesus is offline   Reply With Quote
