Need Engine Advice - ClubRoadster.net
Old 01-16-2007, 02:09 PM   #1 (permalink)
Esteemed Member
slutz4's Avatar
Default Need Engine Advice
Im replacing my head gasket, and my timing belt, and the seals and such that go with a timing belt kit, Im just wondering since Im doing all of this, is there anything else that I should replace or look at when I have my engine apart???
slutz4 is offline   Reply With Quote
Old 01-16-2007, 05:24 PM   #2 (permalink)
Default Re: Need Engine Advice
I hear it is easier to port and polish the heads while you have them off...
Powder coat the valve cover and intake...
Clean the engine bay !!!
replace the engine mounts...
The possibilities are endless. Depends on how long you can have it apart for.
boston813 is offline   Reply With Quote
Old 01-16-2007, 05:52 PM   #3 (permalink)
gwilo's Avatar
Think water pump.
For just the cost of the pump you will save yourself a few hours later on
"Life isn't like a box of chocolates....it's more like a jar of jalapenos. What you do today might burn your backside tomorrow!"
gwilo is offline   Reply With Quote
Old 01-16-2007, 06:05 PM   #4 (permalink)
Esteemed Member
slutz4's Avatar
anyone know the best place to get these things, gomiata has oem parts reasonable, are any other brands good?
Old 01-16-2007, 06:18 PM   #5 (permalink)
gwilo's Avatar
http://www.finishlineperformance.com/
AKA Rosenthal Mazda
Old 01-21-2007, 02:07 AM   #6 (permalink)
Hi Im Simon's Avatar
i would suggest front main oil seal?
simon
simon
"Friends don't let friend drive on ROTAS,
@#%! your fake wheels"
http://www.stopbuyingrotas.com/
Hating is hard work!
Hi Im Simon is offline   Reply With Quote
Old 01-21-2007, 12:29 PM   #7 (permalink)
replace every gasket and some seals. Clean any carbon deposit or grime off the pistons. Those are thing I wish I would have done when I had my head off. Now I'm too lazy. =(
Miazda318 is offline   Reply With Quote
Old 01-23-2007, 09:20 PM   #8 (permalink)
Head studs. I went ARP.
firedog25 is offline   Reply With Quote
