Valvecover question - 1.8 fitment - ClubRoadster.net
Old 12-27-2010, 10:36 AM   #1 (permalink)
Default Valvecover question - 1.8 fitment
Did a search and didn't come up with much. I was looking to get a different valvecover with the raised words to have it painted wrinkle red but wanted to know if it will fit my motor. It's a 99 Miata with the stock 1.8. Right now my current one has recessed wording and I don't like the valvecover being all in one color. I was planning on sanding the lettering down to a polish finished with the wrinkle red. Images are borrowed, not mine.
Want one like this:
Currently:
SLVMX5 is offline   Reply With Quote
Old 12-27-2010, 11:08 AM   #2 (permalink)
RedNeckSmoker's Avatar
Default Re: Valvecover question - 1.8 fitment
i thought the 1.6 had the recessed letters and the 1.8 had the raised letters
97 M edition(toast)rip
92 red parts car
96 white na-Teins,FM sways F/R,corksport spec exhaust,
OG Sukuras,Bomex spoiler,autokenexion Na-NC hybrid bumper
95 Z32 300z (traded)
RedNeckSmoker is offline   Reply With Quote
Old 12-27-2010, 11:16 AM   #3 (permalink)
I wanna go fast
dliverance's Avatar
Where are you located? I know euro NB's have a 1.6 motor as well.
1988 CRX Si- Daily, Autox whore
1993 RX7- Project,Garage queen
dliverance is offline   Reply With Quote
Old 12-27-2010, 11:45 AM   #4 (permalink)
Whiskey makes me Frisky
Skinnyroadster's Avatar
the cam angle sensor is in a different location from 1.6 to 1.8
Originally Posted by aarrowadscom View Post
That's it. That is the post that has killed me.
Forever in my heart.
http://25.media.tumblr.com/tumblr_m2...9ako1_1280.jpg
http://25.media.tumblr.com/tumblr_m7...9ako1_1280.jpg
Skinnyroadster is offline   Reply With Quote
Old 12-27-2010, 11:56 AM   #5 (permalink)
Addicted Member
Pharo_X's Avatar
That top one from a 1.8 engine will not fit the recessed 1.6 valve cover because of the CAS placement in the back area.
The 1.8 Cam Angle Sensor is on the driver side and the 1.6 VC is on the Passenger side.
You'll need to get a VC from a Capri as below to fit the 1.6 engine.
_
http://www.Pharo_X.imagekind.com <-- Check out my Art Gallery
http://www.redbubble.com/people/pharox
Pharo_X is offline   Reply With Quote
Old 12-27-2010, 12:10 PM   #6 (permalink)
_
Why? Hes got a 99 with a 1.8
Old 12-27-2010, 12:24 PM   #7 (permalink)
Lit like a BranchDavidian
Doppelganger's Avatar
Wow...that got over-analyzed with a quickness.
No easy valvecover swap for a 99. They all have recessed lettering. 01-05 won't fit (I'm sure someone will suggest that by thread's-end). Only the 94-97 1.8L have the raised lettering (OK the MSM does as well, but good luck getting a MSM valvecover).
If you really want to get creative and have the raised lettering, you can use the 94-97, but you'll have to find a way to mount the cam sensor to the front of it like your 99 has. You'll need the block off plate from your 99 for the CAS area. Ever wonder how people do that 99 head swap into a NA and retain the NA valvecover? The same operation but reversed.
Here is a NA with a NB head running the NB valvecover...using the NA CAS on the back of the head.
And RevLimiter's NA with NB head and NA valvecover. Note the raised lettering of the NA valvecover and the intake manifold of the NB.
This is the part you'll need to figure out if you're going to make it work....the cam sensor for the 99+.
2002 Ti SE Turbo
Doppelganger is offline   Reply With Quote
Old 12-27-2010, 12:56 PM   #8 (permalink)
basically unless you want to do a decent amount of modding to a 94-97 valve cover, you're screwed unless you find a MSM valve cover.
s!lv!a is offline   Reply With Quote
Old 12-27-2010, 03:52 PM   #9 (permalink)
Damn! Too much work. Guess I'll just paint the one on the car and make something work.
Old 12-27-2010, 07:17 PM   #10 (permalink)
Dustinlib's Avatar
what about the protege/ escort cover?
www.gunshowracing.com
Dustinlib is offline   Reply With Quote
Old 12-27-2010, 10:17 PM   #11 (permalink)
Read thread.
Use deductive reasoning.
Answer own question.
2002 Ti SE Turbo
