Lightweight flywheel/pressure plate combo! - ClubRoadster.net
Old 11-16-2011, 03:18 PM   #1 (permalink)
Default Lightweight flywheel/pressure plate combo!
Hey guys!
I was just wondering about 949 single or twindisk clutch vs 1.6 vs 1.8 (what I have stock '00)
I only daily drive the car, how would you describe it in city driving?
Does a smaller clutch require more slipping?
Also, how was the install, I have read that it's trial/error for the twin disc?
if it's difficult, my plans are to get a fidanza 1.6 (~7lbs) and spec pressure plate (6 or 9lbs depending if it's aluminum, a diff of 3lbs and ~300$). I don't think it's worth it though, but once your light, why not go all the way?
Thanks,
John
2000NB Silver/tan. Done: MS3x, FM springs. To do: TR c1's 15.7.5's BilsHD's.Sways.rails Build thread
Originally Posted by Spettro View Post
And silvermazda has down syndrome. It's been confirmed.
silvermazda is offline   Reply With Quote
Old 11-16-2011, 05:52 PM   #2 (permalink)
Hardparker Extraordinaire
Broketuner's Avatar
Default Re: Lightweight flywheel/pressure plate combo!
Since you also made a thread I'll just post this here:
949 twindisc review
949 ORGANIC twindisc
I would highly suggest also doing the rear main seal...that ended up prematurely killing the discs because someone claimed to do it then months later adimted to not doing it....FUCK YOU RT!
'01 IS300 the fun "adult/family" car
SOLD '99 10AE #5722 MSM front end, 949 twindisk & BRK, JIC FLT-TAR, autokonexion fastback, chaser Scoote2 hood & a little more than the usual weight reduction
Broketuner is offline   Reply With Quote
Old 11-17-2011, 02:26 AM   #3 (permalink)
Okay, read your thread and on the one yr update you mention a 1.6 slipping after a year.
This is partially the way I was going to go..so I have to ask how aggressive do you drive? And do you think it would suit me? I drive like a grandma 70% of the time. (shift at 3K, short city route with lots of stop lights (lots of clutch slipping/shifting).
Old 11-21-2011, 04:36 AM   #4 (permalink)
slipNslide's Avatar
clutch wear often occurs when slipping your clutch to move slowly or holding yourself on a hill.
Driving hard (granted you shift smoothly) wont accelerate clutch wear as much.
Miata owners; when a group is picked on so universally, it creates a brotherhood like no other... Except those m.net fools they don't know shit.
2001 Mazda Miata - red RACE CAR Build Thread
1992 Honda Accord LX Sedan - white PROJECT DAILY Build Thread
slipNslide is offline   Reply With Quote
Old 11-21-2011, 10:07 AM   #5 (permalink)
KazeSpec Engineering
hnguyen037's Avatar
i wouldn't use those in a daily driven car
hnguyen037 is offline   Reply With Quote
