#93 (permalink) |
Fm style loop? Or just pressure line/return line loop?
2000NB Silver/tan. Done: MS3x, FM springs. To do: TR c1's 15.7.5's BilsHD's.Sways.rails Build thread |
#94 (permalink) |
Accepting donations.
When people say FM style I thought it was referring to dissembling the rack and removing the seals.
#96 (permalink) |
There is one loop and its the loop on the steering rack. You can loop the lines on the pinion if you like, but its not needed. I capped those.
FM cuts the seals (ie remove the seals and fill with grease). You can take it a step further and weld the input shaft thing so there is zero play (but you need to be careful with that). |
#97 (permalink) |
I booked marked the weld thread. But I'm not ready to take the rack out, how about one I can do with the car on the lift?
#100 (permalink) |
Hardparker Extraordinaire
You must not've seen the 949 twindisc on that list also forgot to mention header for those with a cast iron boat anchors like NB1's either a stripped down(remove brackets for heatshields & just run a track dog header blanket) '01+ header or aftermarket save a sginifigant amount of weight, looks cool and gains some whp's and as mentioned the rear muffler is HEAVY....on my NB I simply deleted it and added a turndown tip off the midpipe...a little aggressive sounding but not super loud IMO...I only got pulled over once around midnight on a street with a bunch of bars |
'01 IS300 the fun "adult/family" car ![]() SOLD |
