Lifter Tick Or Valve Tap?? HELP!!! - ClubRoadster.net
Old 06-15-2012, 10:21 PM   #1 (permalink)
touge_run's Avatar
Default Lifter Tick Or Valve Tap?? HELP!!!
Ok so my good friend teammate and fellow CR member drive the canyons ALOT and after a uphill run my motor started making a noise, i think its valve tap due to a bent valve, and my friend says its lifter tick due to a starved lifter, sooooo, witch one is does it sound like? and witch one is worse? im not a mechanic and i dont know much, any help would be appreciated
http://www.youtube.com/watch?v=sIMoZU7ERlI
touge_run is offline   Reply With Quote
Old 06-15-2012, 10:52 PM   #2 (permalink)
whinin's Avatar
Default Re: Lifter Tick Or Valve Tap?? HELP!!!
Dunno. Let it run for 30 seconds or so then shut it off. Let it sit for about 5 minutes then start again. I just recently did some head work and did not soak the lifters in oil when removed. So I had the most unbearable lifter tick. After about 6 or 7 start ups it went away.
whinin is offline   Reply With Quote
Old 06-15-2012, 11:05 PM   #3 (permalink)
touge_run's Avatar
when i do that the sound get a little quieter but its still there
