Cam Shaft Help? Car not starting.. (1996 NA) - ClubRoadster.net
Old 06-20-2012, 01:53 PM   #1 (permalink)
NyanCat's Avatar
Default Cam Shaft Help? Car not starting.. (1996 NA)
Ever since I bought my car I noticed a clinging sound coming from the engine. I had a friend diagnose it and tell me it was the lifters being stuck and old. I decided to take apart my engine and clean each lifter. The lifter cleaning worked with a few DIY's I found online:
http://www.miata.net/garage/hla/cleaning.html
http://forum.miata.net/vb/showthread.php?t=208366
http://www.youtube.com/watch?v=RX3vnnq4y7M
Each lifter I cleaned had disgusting black grimy oil in it and I cleaned eight of the sixteen.
What I had a problem with is dealing with the Camshaft and putting that and the timing belt back on the right way.
I shouldnt of done it but I guessed where it was (The Cams) before I put it all back together. Because once I put it all back together and started the car it would not start. It sounded as if it wanted to but it didnt.
I'm thinking I should take it all apart again (keep it in neutral) and place the cam shafts and the gears with the lettering matching the engine as this guy did when he put it back together:
http://www.youtube.com/watch?v=YHRfW...feature=relmfu
Yes the lifters all work as if they were brand new after I cleaned them all and placed them back into their original holes/position.
NyanCat is offline   Reply With Quote
Old 06-20-2012, 01:56 PM   #2 (permalink)
//reported
phillyb™'s Avatar
Default Re: Cam Shaft Help? Car not starting.. (1996 NA)
yeah, it needs to be timed correctly.
if you eyeballed it...chances are you fooked it up
you want a decal
phill out the phorm on my site - phillybhateme.com
@phillybhatesme on instafag
phillyb™ is offline   Reply With Quote
Old 06-20-2012, 02:01 PM   #3 (permalink)
NyanCat's Avatar
After I put the timing belt gears into place with the cam shafts and attempted to start it. Will it damage the engine in any way? or will just placing the lettering 'I' and 'E' on the gears with the engine work while in neutral? should I put it in any gear before matching them up?
Old 06-20-2012, 02:05 PM   #4 (permalink)
//reported
phillyb™'s Avatar
you should do whatever this says - http://www.miata.net/garage/timingbelt.html
you want a decal
Old 06-20-2012, 02:08 PM   #5 (permalink)
NyanCat's Avatar
I'm going to try that
Thanks for the help! Let's see if this works..
Old 06-21-2012, 11:01 AM   #6 (permalink)
NyanCat's Avatar
Thought I fixed it. Turns out I didnt.. Now it wont start and after putting the key in there and attempting to start it it tries to start.. then go thump and then tries to start itself again.. also some smoke comes out of nowhere?
Old 06-21-2012, 11:41 AM   #7 (permalink)
brontosaurus
1vicissitude's Avatar
Get someone to retime it that knows that they are doing. Your doing something wrong. Being in gear or neutral really has nothing to do with anything. I think it's fairly clear you are way over your head man.
Did everything line up exactly like those pictures? Do you have the correct plug wire feeding the right cylinder?
You could have rotated the CAS 180 degrees when you were removing the cams.
Sounds to me you have fucked with it so much now you are going to have to find TDC manually. Find the top of cylinder ones stroke by putting a screw driver in the spark plug hole. Then use the pulley markings to measure it precisely.
Who knows where in the cycle you have this thing lol.
Originally Posted by sdemo45 View Post
Ain't no MTn fast enough;
Ain't no RD low enough;
Ain't no Mnet stock enough;
To keep CR from swaggin wif you, babe.
1vicissitude is offline   Reply With Quote
Old 06-21-2012, 11:46 AM   #8 (permalink)
your cam timing is still off.
Braineack is offline   Reply With Quote
Old 06-21-2012, 11:46 AM   #9 (permalink)
no dude.
Old 06-21-2012, 12:02 PM   #10 (permalink)
brontosaurus
How many teeth are between the pulleys, should be 19.
Old 06-21-2012, 12:50 PM   #11 (permalink)
Accepting donations.
adamvanxxx's Avatar
You can't rotate the CAS 180 it only goes in one way.
Originally Posted by kawaii_kawaii View Post
My car
adamvanxxx is online now   Reply With Quote
Old 06-21-2012, 01:12 PM   #12 (permalink)
NyanCat's Avatar
I'll have someone do it.. hopefully it doesnt run me alot..
Old 06-21-2012, 01:16 PM   #13 (permalink)
brontosaurus
Your in redlands, see if any of the local miata peeps can help spin a wrench. It shouldn't take someone who's done it before much time at all.
Old 06-23-2012, 03:23 AM   #14 (permalink)
NyanCat's Avatar
She's aliveee!! I'd like to personally thank 91Radio Flyer, djdeluxept, WildCJ5, emtran, Conundrum, Braineack, 1vicissitude and I'd also like to thank PhillyB..
The problem was that the crankshaft needed to be in T.D.C., which meant I had to take out fuses and measure and some other stuff!
Old 07-04-2012, 06:44 PM   #15 (permalink)
NyanCat's Avatar
Soo.. I'm having this exact same problem and am working with no space at all.. Any advice on how to get the lock off?
http://forum.miata.net/vb/showthread.php?t=394887
There is one long bolt that is there & really really hard to get to.. it's a 12mm, should I buy a skinny 12 point socket wrench with a bend on the end and put it through? This is honestly being a huge pain..
EDIT: Did what I said I would.. Cam is off.. I win you piece of shit bolt... Haha
Old 07-05-2012, 07:47 AM   #16 (permalink)
you cant reach the cas lockdown bolt? lol.
here bro: http://www.amazon.com/Mintcraft-Ratc.../dp/B005QC7CRG
Old 07-05-2012, 03:10 PM   #17 (permalink)
NyanCat's Avatar
No, I got to it lol just having other issues at the moment..
Cleaned every lifter.. still engine sound :(
Old 07-18-2012, 04:38 PM   #18 (permalink)
NyanCat's Avatar
Haven't posted on here in a while. Car works perfect.
