Oil filter removal help. - ClubRoadster.net
Old 07-04-2012, 06:01 PM   #1 (permalink)
pandita's Avatar
Exclamation Oil filter removal help.
I can't get it out.
I've tried everything, old style filter wrench, one that uses a socket, bare hands.
I can't get it out.
someone suggest puncturing it with a screwdriver and twisting it off, but even if I did I'd have no space to turn the screwdriver.
How do you guys do it?
pandita is offline   Reply With Quote
Old 07-04-2012, 06:18 PM   #2 (permalink)
Kaldar142's Avatar
Default Re: Oil filter removal help.
take off the wheel and go through the wheel well, you can get a decent sized tool in there, just watch the starter and alternator terminals...
i'm a tech and when all else fails i've never had a problem using these with stubborn oil filters... just grip em tight
http://supertoolss.com/wp-content/up...ter-wrench.jpg
NA6 Turbo Miata
NA8 Spec Miata
Kaldar142 is offline   Reply With Quote
Old 07-04-2012, 06:20 PM   #3 (permalink)
theasian100's Avatar
I get mine out using my hand. Reach from underneath the car near the passenger side wheel. They say you should be able to get to it from above, reaching under the IM though.
theasian100 is offline   Reply With Quote
Old 07-04-2012, 06:23 PM   #4 (permalink)
Yea its really easy to get from the top.
Sent from my MB855 using Tapatalk 2
Frankie850 is offline   Reply With Quote
Old 07-04-2012, 06:30 PM   #5 (permalink)
TwiztOG43's Avatar
Yea, the miata oil filter is one of the more easier ones to get out. If it is stuck, get a couple rubber bands and wrap it around the oil filter. That should get it out.
1993 Mazda Miata
2005 Mazda RX-8
1994 Mazda Miata (Girlfriend's car)
TwiztOG43 is online now   Reply With Quote
Old 07-04-2012, 06:37 PM   #6 (permalink)
pandita's Avatar
Whoever did this last time over tightened the shit out of it.
I've tried two people twisting at the same time from the top and bottom, and everything else.
And I was trying to puncture it with the screw driver but I can't get enough leverage to jam it in.
Old 07-04-2012, 06:38 PM   #7 (permalink)
oldcracker's Avatar
get one of these things at walmart for a few bucks
oldcracker is offline   Reply With Quote
Old 07-04-2012, 06:40 PM   #8 (permalink)
Have you tried the filter claw with a small extension and a good size ratchet? Works 98% of the time 100% of the time.
imnatelol is offline   Reply With Quote
Old 07-04-2012, 06:45 PM   #9 (permalink)
As said before, get it from the bottom. I just turn the wheel to get it out of the way.
At work, I have one of these: it attaches to a 3/8 ratchet and gives no fucks.
http://www.cornwelltools.com/webcat/...-Filter-Wrench
Current: 94 R Package / Former: 99 Silver PEP
-Scott
2ndGearRubber is offline   Reply With Quote
Old 07-04-2012, 06:46 PM   #10 (permalink)
If yours is as stubborn as mine was (mine wouldn't even come out with oil filter sockets), get a pair of arc joint pliers and go from underneath.
Old 07-04-2012, 07:09 PM   #11 (permalink)
Victim44's Avatar
I second this. It is by far the best way to get to the oil filter.
Mazdaspeed-Beatrush-Carbing-Momo-Daikei-Skunk2-RSR-Harddog
Victim44 is offline   Reply With Quote
Old 07-04-2012, 08:08 PM   #12 (permalink)
demoniam's Avatar
I go under the intake manifold in the NA, just grip and twist
I'm from the internet and i'm here to give you a ride!
My journey
demoniam is online now   Reply With Quote
Old 07-04-2012, 08:13 PM   #13 (permalink)
pandita's Avatar
Welp, I ended up taking it out with something similar to this
It kept slipping and shit because it was made of plastic. but I ended up getting it out with the help of my girlfriend holding everything straight, then turning it from underneath.
Thanks guys.
Old 07-04-2012, 08:47 PM   #14 (permalink)
Plastic cap wrench? Cheapass.
'94 Sepang blue project :: '95 flat black, HT | riced, JR45
'89 2WD, burgandy, Lariat F-150 | leveled w/ 31s
Originally Posted by brontosaurus View Post
Whackamole roadster.
(Adam) is online now   Reply With Quote
Old 07-05-2012, 10:02 AM   #15 (permalink)
When you get it out, replace it with a K&N filter. They have a hex on the end for a socket. Good filters, too.
jonpcovington is offline   Reply With Quote
Old 07-05-2012, 10:05 AM   #16 (permalink)
STLWaffles's Avatar
Originally Posted by 2ndGearRubber View Post
I have both these tools, and between the 2 of them I have never met a filter I could not remove.
STLWaffles is offline   Reply With Quote
Old 07-05-2012, 10:34 AM   #17 (permalink)
Accepting donations.
adamvanxxx's Avatar
If people could just understand to fucking lube the seal and once it makes contact, rotate 1 turn. Done.
For your case crush that fucker with channel locks and twist.
Originally Posted by kawaii_kawaii View Post
My car
adamvanxxx is offline   Reply With Quote
Old 07-05-2012, 11:42 AM   #18 (permalink)
^right?
Dip finger in oil, wipe on seal, don't Hulk that bitch on there
GarageStar
Visit GS
2001 SE NB Racekor: Build Thread
If I've ever sold you a part or bought something from you, please leave me some feedback!
spitefulcheerio is online now   Reply With Quote
Old 07-05-2012, 05:09 PM   #19 (permalink)
estabahn's Avatar
Whoever tightened your filter was a caveman. Mine go on by hand and come off by hand ( from the top ).
Spear it with the biggest screwdriver you can find.
estabahn is offline   Reply With Quote
Old 07-05-2012, 05:15 PM   #20 (permalink)
King of Hella Stance Swag
monkey.magicx's Avatar
Masturbate more, develop those forearm muscles, and manhandle that filter from the engine bay.
92 NA6 - Dead.
99 NB8 - Rice plate.
GarageStar
caosgomoo
Fat Cat Motorsports
monkey.magicx is offline   Reply With Quote
Old 07-05-2012, 06:18 PM   #21 (permalink)
Removing the manifold brace also helps a lot. After you've removed it, leave it off; you don't need it.
lebowski is offline   Reply With Quote
Old 07-05-2012, 06:29 PM   #22 (permalink)
atlnb's Avatar
push-ups and masturbation
Originally Posted by aarrowadscom View Post
That is in fact, non oem spoiler that came as a factory option on NB1, and offered as an aftermarket piece on NB2 available from the dealer.
Xida CS, Hard Dog, Corn*s, Bride, Carbing, Joyfast, Beatrush, 6UL, KG Works, Square Top Manifold
atlnb is offline   Reply With Quote
Old 07-14-2012, 09:24 AM   #23 (permalink)
estabahn's Avatar
Both at the same time?
Old 07-14-2012, 10:57 AM   #24 (permalink)
HighwayStaR*'s Avatar
Double the buffness in half the time!
Power Of The NOVA FORCE!!! Nova Corps TD04 Turbo kit on a stock 1.6,5psi,Begi Downpipe,Mishimoto radiator and fans, Flyin miata exhaust,Greddy turbo timer,Megan Ez Coilovers,HDHCHDDDHHDHDHC Rollbar
HighwayStaR* is offline   Reply With Quote
Old 07-14-2012, 11:02 AM   #25 (permalink)
Rubber dish washing gloves & grow some muscles. Best thing i have used period
RedMX is offline   Reply With Quote
Old 07-14-2012, 11:48 AM   #26 (permalink)
ScarfaceThe91's Avatar
Cock push ups....... Tenacious D style.
ScarfaceThe91 is offline   Reply With Quote
Old 07-19-2012, 11:02 AM   #27 (permalink)
estabahn's Avatar
I'm doing both, but not at the same time. Is fail?
