car won't start...no check engine light - ClubRoadster.net
Old 11-13-2012, 02:19 AM   #1 (permalink)
Default car won't start...no check engine light
when i turn the ignition on i get no CEL light and the car will turn over but not start. bridgeing the fuel pump connecter makes the pump run.
so am i right in thinking its just the main relay? Is there anything else that will stop the CEL from lighting? fuses? Ignition switch?
SLYDIT is offline   Reply With Quote Quick reply to this message
Old 11-13-2012, 09:32 AM   #2 (permalink)
corkscrew's Avatar
Default Re: car won't start...no check engine light
is your airbag fuse blown? i had that happen to me a few months ago. same symptoms. and the no CEL means that the ECU is not getting power
Build Thread
http://ilovedrivingslow.com/feature-rides/simply-put
Instagram: c0rkscrew
corkscrew is offline   Reply With Quote Quick reply to this message
Old 11-13-2012, 10:01 AM   #3 (permalink)
MC70's Avatar
I dunno about the fuel pump behavior, but I recently discovered that if I park mine with the nose pointed down, it will crank all day without starting. Move it to a level position and it'll fire right up.
MC70 is offline   Reply With Quote Quick reply to this message
Old 11-13-2012, 10:13 AM   #4 (permalink)
farmernate's Avatar
Same thing happened to me fairly recently, turned out my coilpack failed and took a relay along with it.
farmernate is offline   Reply With Quote Quick reply to this message
Old 11-14-2012, 12:35 AM   #5 (permalink)
ok so a diagnostics check reveals no codes. i have power to the ecu when cranking and with ignition on. Main relay is switching.
but still no fuel pump with the ignition on and no CEL at all. FP runs with the diagnostics jumper in.
evry fuse in both FB's are good.
Old 11-14-2012, 01:14 AM   #6 (permalink)
Brunettes > Blondes
Dmn2258's Avatar
check your main fuse i had the same shit happen to me and i couldn't tell if the fuse was blown. i replaced it and it worked
1993 Crystal White: 1.8 swap w/ AE101 ITB's,red LE interior swap,APR CF Mirrors,BC Coils,OBX 4-2-1,Megan Exhaust,MS2PNP,FM Sways,XXR531,AK V. 2 trunk, bunch of carbonmiata goodies
my "build" thread: http://clubroadster.net/vb_forum/sho...57#post1319057
Dmn2258 is offline   Reply With Quote Quick reply to this message
Old 11-14-2012, 01:44 AM   #7 (permalink)
when you say "main fuse" do you mean the 80A fuse held in by the bolts in the engine bay fusebox?
Old 11-17-2012, 11:00 AM   #8 (permalink)
Brunettes > Blondes
Dmn2258's Avatar
yep. check all of em
Old 11-26-2012, 11:22 PM   #9 (permalink)
Mendo's Avatar
Thread revive lol. Did you check the actual fuel pump hangar? I had something similar happen to me too and the wire at the top of the the hangar on the inside had burned out.
1994 Montego M-Edition Miata - The DD
2010 Evolution X SE #203/340
Best 1/4 Time: 12.54 @ 107.5 , 1.83 60ft
Mendo is offline   Reply With Quote Quick reply to this message
Old 11-29-2012, 01:37 AM   #10 (permalink)
it was nothing to do with the pump. the pump worked fine when the diag connector was jumpered. It turned out to be corrosion on the ecu board on the 1a/b/c terminals. i cleaned and resoldered the connections and all is good now.
