So I have a new strange noise, makes me sad. :cry2:
Sounds like some type of electric motor to me. I can hear it faintly when traveling faster in 3rd gear and it is loud in 4th and 5th gear. You can only hear it when giving it gas in those gears, in neutral it doesn't make a peep. It is very repetitive and seems to repeat faster as I am moving faster, but again, only when giving it gas.
Also, it seems as if when just barely pressing the gas pedal it is loudest and it seems to quiet some as I give it more gas, but it could just seems that way because other sounds increase as I give it more gas.
Is this a bad sound? Can I fix the sound? What should I do? What is the sound coming from?
