Water inlet pipe. There's a thread on miata.net for it, just can't find it right now. I had a pinhole leak out of the mini pipe coming from it, and used JB Weld to fix it.
you cant even see any cracks or anything but it is coming from there.
its like i fix one hose leak, then another one leaks.
so i did another full system flush. and new thermo. since i have a 54mm core rad.
then im all checking the hoses today and couldnt see anything, and im like wtf is going on.
then force my head under my car and see there is coolant on it and thats where its coming from im about 90% sure.
and it squirts everywhere.
now its looking kinda like maybe from the hose that attatches to it or where the little tiny tube comes from it.
so i jb welded that section and then along the crease of the inlet.
I've had a leak from the top right portion of the water inlet several times. It's a little rubber O-ring that fails. I've also had the little nipple on the left rust out and crack creating a leak.
well seems to be coming from the little hose and fitting that go to the inlet.
then im wondering how in hell its on my front lca.
and im feeling my lower rad hose.
i think it may have a small crack or hole or something and be squirting towards the rear of the car.
but its hard to tell. all i know is these are like 3 month old silicone hose kit.
