The motor, drivetrain,and front/rear subframes are out of my car. Does anyone have any suggestions what I should do while they are out. I know some of y'all think, "if only my motor was out I could do this, or I could do that". What would the this and that be?
For example: Seam welding, install better motor mounts, diff mounts and so on.
You should defiantly paint, when will the opportunity arise again? I'm not talking send it off for a $$$ job. Just some rustolium or something. Clean sub frames and arms look so nice from behind. Its the little things that really stand out and separate the 1k scrappers and the nicer roadsters.
1: mega engine bay cleaning.
2: Swap soft clutch line for an SS one.
3: Install a new speedometer cable while you're at it.
Why?
1: Dirt.
2: I had one burst with the engine in the car. It was a huge huge pain to swap with an engine in the way.
3: I've never actually swapped one of these with an engine in the car. It has to be one of the most annoying jobs I can imagine.
