I've been rocking their cromoly flywheel in the 1.6 for a few months now. Excellent product, so far! It is a little louder on Decel, but all of them are when you go lightweight. Great engine acceleration, and decel, and excellent daily driveability.
I went with an Exedy OEM clutch, though I'm starting to wish that I had "upgraded" while the car was apart.
I called around; and to lighten and balance the OE flywheel was going to cost me $150, so the F1 price is worth the extra time and hassle.
I have had one in my car for about two months. I have not had any problems with it. Just check with them as the batch I got mine from had the pressure plate holes tapped wrong, they told me before I ordered. I got a set of bolts from ARP for $17. Put it in with the upgraded O.E. clutch. Love it.
well first off, its a 1.6 clutch in a 1.8 , making at least 140 at the crank.
the stage 1 is organic, its rated at like 177ft lbs torque. i bought it off ebay from gripforce.
i had it installed by Roadstertuner. he did a great job. it was installed along with a 6 speed swap.
i did the 500 mile break in , and on the 500th mile , i was at adams kart track. i noticed somewhere around that time that it would Slip if i tried to make it chirp in 2nd gear. just recently, at Buttonwillow, (2 track days later,1 autocross, and 3 adams short track days) it showed me its true colors, out of the grid, it slipped all the way through 1st , and 2nd. till i let off . now if im nice it wont really slip ,or noticeably so, but im not sure it will last.
so im trying to get a hold of Gripforce to return it. but that means i have to pull the tranny again.
cause its NA, and the smaller setup has less rotational inertia. common trick . its all over 949's site.
didnt ya know.
also the F1 pressure plate feels like pillows next to the oem Exedy i replaced it for.
+ 1 on the F1 stage one slipping for the one 1.6 mine does all the time when im getting into it. but im going to keep it till i get a light wait flywheel. how ever it is relly nice to dd on. let us know how the fly wheel goes.
2 months ago . i have an F1 1.6 flywheel. it seems fine. i dont think the clutch is engaging fully.
it has trouble going into 1st randomly.im not happy , im going to buy the Exedy Stage 2 tomorrow.
i love exedy . i dont know why i bought this other cheap ****.at least it was only $87.
i just talked to GripForce today , they are trying to say i abused the clutch by taking it to the track. he said it was heat that was causing it to slip , basically that i was burning it up . i am the nicest guy i know to parts. my **** is as babied as a driven part can be.
GripForce description on ebay
F1 RACING STAGE 1 clutch kit is an upgrade heavy-duty clutch set up for those who seeks streetable high peformance clutch. It is a direct factory replacement parts thus no modifications are needed. The clutch kit includes only the highest grade components and it's ready for hot action on street and track. The premium organic friction material for high heat tolerance, quick recovery, good friction and long life. The heavy-duty sprung center unit boasts heat treated springs and retainer rivets for the maximum power and durability. The F1 Racing pressure plate features special single diaphragm design to increase clamp load. It features induction hardened diaphragm, CNC machined castings, stronger drive straps and rivets. F1 Racing pressure plate provides smooth and precise feel with easy modulation. All F1 Racing pressure plate is load tested on a special testing tool for quality assurance.
so i sent them their description with the same parts marked in bold.
next . im going to go throw it through the front window of Gripforces office.
:fp:I really don't know how I missed that.
I was more interested in the Stage one clutches as opposed to the OEM replacement, but did not specify when I should have.
Yes u are right.
HOWEVER..
If U build clutches. Then u know the only thing Exedy about the F1 PP is the body. V
Exedy / Dakin also sells the 100$ "Cheap clutch kit"
This would be the same PP as the f1 kit. Sad, Less holding power than a 3 yr old girl walking my neighbors mastive.:fp:
Exedy oe is a tamer version of the Exedy stage 1 PP
Exedy stage 1 is very close to the OE PP except for stronger straps.
And strap strength goes up yet again with the stage 2 exedy. Thick or thin.
Hope this clears things up.
If not Goodwin racing has great insight on his website=]
If your driving the car HARD.. Get Stage 2
Stage 1 In 1994-2004 (1.8) is good too.
I have just under 50K on my Exedy stage 2 Thick,paired with Toda race FW 1.6 versions
I run an ORC (Ogura Racing Clutch; A "matched" setup) In the MC track car.
BTW the SM frontrunners use Exedy stage 2 (1.6) & the lightest FW they can find for the money. f1? ACT?
If money is no option .. COMPETITION CLUTCH (949R Twin Disk) is light & strong. Only need a nice clutch pedal stop. This is also a "matched" setup.
Hope this helps:fab:
Tossing a wrench into the OP query. I've had the XTD 6puck clutch & chromo 9lb flywheel.
DEFINITELY get a lightweight flywheel while your doing this. I think this is one of the best NA upgrades.
Only negative thing i have was/still is 'chatter' that is noticibly loud between 3k-4k when i'm off the throttle in 2nd/3rd/4th gear. First i thought it was the tranny going.
Not sure how the F1 is for longevity, but if it's on 949's site.... gotta be good right?
