Car: 1990 MAzda Miata 1.6L
Miles: 170k
Last started: 3 months ago
edit: Has fuel stabilizer since I knew she wouldn't be started for awhile
This past weekend I finished buttoning up some of the other projects I've been working on. And prepped everything for her to be started (oil change/filled with coolant etc). So I go to start her up, and she turns over, but won't fire up. I noticed that I couldn't hear the fuel pumping whining behind me. With the help of a friend, I checked the relay. I had him turn the car from off to ACC and I could feel the relay clicking each time. Went and got a new fuel pump/screen, put it in, and hooked everything up. And I'm still having the same problem.
I found 2 threads that were kinda related to mine
1) http://clubroadster.net/vb_forum/showthread.php?t=23146&highlight=fuel
- ended up getting his started, and it wasn't the fuel pump
2) http://clubroadster.net/vb_forum/showthread.php?t=33046&highlight=fuel
- ended up being the CAS
So I'm guessing the fuel pump isn't getting power, how would I go about verifying that? And correcting it, if that is the problem?
Miles: 170k
