Hey Just have 2 head scratching problems
1. Turning off the car the engine shakes (2-3sec) then a nice crisp clunk, or valve tap?
Could be engine mounts bad? Is this Normal?
2. Between shifts and around 2300-2500rpm range I get the grind/heat shield like rattle?
I rippd my catback heat shield off, changed diff and trany fluid also, Is this diff mounts? or u joints?/
