hello, i have searched, but i cannot find out how to remove/replace the thermostat housing (inlet). there is two bolts that goes into the engine. please help
Remove everything that you would take off for a timing belt, especially the cam gears and backing plate. Then with all that out of the way, it should be pretty self explanatory.
ok, so this would be a pretty long procedure. thanks
