I have a 96 stock 1.8 motor and seem to be running extremely lean. I can tell this because my plugs are white as crap. It hesitates down in low rpm range under 3000 usually and only hesitates when I seem to give it throttle. Like its not getting enough gas and sputtering some. The noise it makes: brbrbrbrbrbrrbwahhhh
The noise it should make:Bwahhhhhhhhhh
^^lol
I had a vacuum leak and its gone now since it runs fine idling. I unhooked the batter thinking it may reset and sure enough didn't. I was thinkin a clogged fuel filter or maybe fuel injectors or ever FPR going bad somehow... (just thought of fuel pressure regulator...checking that in morning now.) Any other thoughts of what this could be?
^^lol
