I found broken blue pieces scattered on my drivers side floor. then i noticed a clicking noise when i let go of the clutch pedal. does anyone know what this little blue piece is, or where it goes? i can see where the noise is coming from.
this is the blue piece that i put back together for picture purpose.
does the blue piece go inside the clutch pedal assembly and press against the white button?
where can i buy one?
the little white piece clicks when it trys to go inside the hole on the clutch pedal.
