Since this is a decent topic that does come up from time to time. I think maybe a thread with everything in it will be a good idea so that way we can learn more before it happens on here. Useful tips and what not to help others along the way if you will.
I have a few questions myself....
I need to torque down the flywheel, and pressure plates and need to know the specs, can anyone help me out and tell me by chance? I don't have a manual and no money to help purchase one.
2nd, the thermostat housing on a 1.6, has a sensor in both the back and the front of the motor and which case the 1.8 only in the back. I took the sensor from the 1.6 in the back and put in the back of the 1.8 so the clips matched up. What do I do about the front one in the motor?
Any special ways to get the header off besides manning up? :dunno:
There is a single wire in the back of the 1.6 that is connected to the injector wire and thermostat? wire. Single and goes into the housing in the back of the motor. If thats a ground I can deal with it once its together.
I think I needed to ask a few others just cant remember right now.
I can get pictures also if any are needed. I know there is a search feature but why search around when all the information can accumulate into one spot.
