Hi all,
i'm trying to get my NA8 mx5 in good shape for a future planned turbo set u.
Its got 125k miles on the clock so i'm going to put new bearings, piston rings and bolts on there just to make sure its running as good as it can.
The one thing i'm wondering about is a coolant reroute, the turbo I want to use is the IHI VF24 from a scooby (only because its ball bearing, good, and cheap) and its water cooled so i'm going to need to route the coolant lines to run through it.
I wanted to know what DIY options people have done to 1. re-route the coolant, and 2. route coolant to the turbo etc.
Cheers
Tom
Cheers
Tom
