installed my 323 GTX turbo cam cover ... - ClubRoadster.net
Old 01-22-2007, 04:34 AM   #1 (permalink)
retrorocket's Avatar
Default installed my 323 GTX turbo cam cover ...
did a quick check with my 323 cam cover to see that it will all fit okay before I finish polishing it ...
retrorocket is offline   Reply With Quote Quick reply to this message
Old 01-22-2007, 07:50 AM   #2 (permalink)
ClubRoadster.net Founder
timallen's Avatar
Default Re: installed my 323 GTX turbo cam cover ...
What are you going to do about the rear vent tube and mounting the coil pack?
Tim (Toolman) Allen
1993 Mazda Miata Limited Edition #790 of 1500
Black with Red Interior
timallen is offline   Reply With Quote Quick reply to this message
Old 01-22-2007, 07:59 AM   #3 (permalink)
ha ha ha ... I thought this would grab your attention Tim !
rear vent tube was easy cos this cover doesn't have one - 323 GTX TURBO 4X4
the coil pack is still attached via the dingle bolt at the back into the head block ... I will fab up a couple of small brackets to hold the 2 upper mounting points
I will have to find out from someone with a little more than my pretty limited mechanicak knowelage if I need to remove the baffle from the PCV outlet and just connect with a hose to an oil catch tank or whether I should just leave the baffle in and connect up !!?
I just wanted to check that there weren't any fitment issues with the coil pack etc before I fit for good and get thinks ready for installing my IRTB's
Old 01-22-2007, 08:03 AM   #4 (permalink)
timallen's Avatar
Curses!
Well, I did a test fitment of mine before I had to send it for a re-spray and if I mount the coil pack using that single bottom bolt, the rear vent tube falls right bewteen the two coil packs. I just don't know how I am going to get a tube on there yet. I may try an "L" fitment. In any event, I have looked at the setup of both the GTX and the Capri turbo and the rear vent tube goes right back into the air intake tube, so I'm pretty sure both vent tubes can go into my oil catch can.
Keep us updated. My GTX cover should be here this week.
Tim (Toolman) Allen
Old 01-22-2007, 08:05 AM   #5 (permalink)
Tim you can just seal up the rear outlet ( AFAIK ) as long as you have one venting to your oil catch tank ...
Old 01-22-2007, 08:07 AM   #6 (permalink)
timallen's Avatar
I was wondering about that.
It looks like the tubes vent different baffles. You sure about this? That would be good.
Tim (Toolman) Allen
Old 01-22-2007, 08:09 AM   #7 (permalink)
I am not 100% sure, maybe ask Peter ?
the FujiRacing instructions for the IRTB kit doesn't have a problem with sealing off the PCV outlet on the standard 1600 manifold an using the L/H one to the oil catch tank
Old 01-22-2007, 08:16 AM   #8 (permalink)
timallen's Avatar
Well that's true.
I guess I'll try that and see what happens on the short term.
Tim (Toolman) Allen
Old 01-22-2007, 09:02 AM   #9 (permalink)
Speed Racer
XCLR8TN's Avatar
Is that... sparkly? Or is it just paint flecks or something? I think the cover looks good
_Jess_
1991 White Mazda Miata DD
1991 BRG Mazda Miata
LS6 swap ...SOON
XCLR8TN is offline   Reply With Quote Quick reply to this message
Old 01-22-2007, 09:05 AM   #10 (permalink)
... it's gold metalflake with coloured glitter in the powdercoat 8)
theexterior and interior of my car all pretty subtle ... thought I would have some fun with the engine bay - I have my radiator slam panel and fron brace brackets powdercoated in the same colour too
