Aftermarket intake manifolds? - ClubRoadster.net
Old 05-07-2011, 10:18 PM   #1 (permalink)
Bobthewisemonkey's Avatar
Default Aftermarket intake manifolds?
Does anyone know of a company that makes an aftermarket intake manifold for the 99 and up miatas? Did some searching and coulden't come up with anything. Help?
Bobthewisemonkey is offline   Reply With Quote Quick reply to this message
Old 05-07-2011, 10:19 PM   #2 (permalink)
(ಠ_ృ)
brontosaurus's Avatar
Default Re: Aftermarket intake manifolds?
No. If you're making enough power to warrant one, you'll find someone to make one for you.
Old 05-08-2011, 02:11 AM   #3 (permalink)
RedemPhex's Avatar
yeap. couldn't have said it better.
with that said, if you want to waste your money I know track dog has modified people's intake manifolds for them before. Contact them.
Old 05-08-2011, 02:14 AM   #4 (permalink)
Supporting Member #5522
j-radvw's Avatar
BEGI
http://www.bellengineering.net/produ...roducts_id=256
Miata Build thread
Jeep build Thread
911 build thread
j-radvw is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 03:00 AM   #5 (permalink)
R U ?
horribleR's Avatar
Originally Posted by Begi
Otherwise, lower horsepower cars will loose power.
Loose power...chit be crazy wobbly son!
horribleR is online now   Reply With Quote Quick reply to this message
Old 05-08-2011, 03:04 AM   #6 (permalink)
PocketAce's Avatar
Wobbly power sucks.
There are people adapting Honda B16/B18 manifolds (specially the cool Type R manifold) to fit the Miata head.
Regards; Andre
President of the "I had a Miata" club.
PocketAce is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 03:22 AM   #7 (permalink)
Phung018's Avatar
lose vs loose.
english.
english.
BUILD
Phung018 is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 11:14 AM   #8 (permalink)
Well I guess that about sums it up for me. Thanks for the input.
Old 05-08-2011, 02:06 PM   #9 (permalink)
redeunos's Avatar
new manifolds aren't hard to make if you can weld. The BEGI manifold will give you more top end power but reduce you low end torque and i like torque, so i went with runners. I made this manifold for my 1.6 for under $150. I am going to use it with a supercharger setup using a larger throttle body. Yes the stock manifold we welded the runners to are port matched to my P&P head.
Phone pics.. so they kinda suck.
redeunos is offline   Reply With Quote Quick reply to this message
Old 05-13-2011, 03:30 AM   #10 (permalink)
BracedEunos's Avatar
BracedEunos is offline   Reply With Quote Quick reply to this message
Old 05-13-2011, 03:49 AM   #11 (permalink)
shuai8089's Avatar
pit garage
9654 Alpaca St
South El Monte CA91733
shuai8089 is offline   Reply With Quote Quick reply to this message
Old 05-13-2011, 03:53 AM   #12 (permalink)
Phung018's Avatar
braced, have you updated your awesome build thread?
BUILD
Old 05-17-2011, 04:11 PM   #13 (permalink)
garageSTAR Supporter
jdmfc3s90's Avatar
Its not custom, but i believe the Jdm 01+ intake manifold warrants some power. I know miataroadster.com selling them for 5 bills, or you could search ebay.
Visit-
jdmfc3s90 is offline   Reply With Quote Quick reply to this message
Old 05-17-2011, 04:14 PM   #14 (permalink)
Lit like a BranchDavidian
Doppelganger's Avatar
Only if you have a NB/NB head.
If you're not boosted, changing IMs will only net you ricer points at car shows.
2002 Ti SE Turbo
Doppelganger is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 11:52 AM   #15 (permalink)
Isn't the JDM intake manifold (square top) good for about 5-10 horses?
So I would say that serves as more than just points at a car show.
my97miata is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 11:59 AM   #16 (permalink)
jdmfc3s90's Avatar
It is a square top. Emilo is using one on a motor he has. I was reading up on a thread here. Its true its only bolt on for NB heads, but it is worth more power, not just rice. FYI miataroadster sells a adapter plate to make the jdm Intake fit on NA's. You just got cut and weld it on.... Easy right...
Visit-
Old 05-20-2011, 12:16 PM   #17 (permalink)
I can haz custom title!
Originally Posted by BracedEunos View Post
DO WANT!!! nb head only?
"When life throws an unexpected curve, brake late and accelerate early."
- Me
sydwayz is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 12:41 PM   #18 (permalink)
thasac's Avatar
search 'flipside' on here or MT.net.
-Zach
thasac is offline   Reply With Quote Quick reply to this message
Old 05-30-2011, 10:39 AM   #19 (permalink)
bug man nrg's Avatar
this looks good nice work
bug man nrg is offline   Reply With Quote Quick reply to this message
Old 05-30-2011, 01:58 PM   #20 (permalink)
Its a 1.6. Click on vid below
Old 01-28-2012, 10:20 AM   #21 (permalink)
Laguna96's Avatar
sorry to revive a dead thread, but i have been trying to find info on the b16/b18 adapter/custom builds but i cant find it in the search. other forum maybe? anyone have a link?
Laguna96 is offline   Reply With Quote Quick reply to this message
Old 01-28-2012, 11:19 AM   #22 (permalink)
Official Armchair Racer
stormin'norman's Avatar
Google is a very powerful tool. Try over at MT
Old 01-28-2012, 05:14 PM   #23 (permalink)
BEGI had one in "final testing", but then it just dissapeared from their web site, it was a more middle of the road manifold than the one they are selling. I'm curious to know what happened to it.
Jim
My miata: 2001 Miata LS with 6 speed, sport suspension and ABS
Jimj64 is offline   Reply With Quote Quick reply to this message
Old 01-28-2012, 05:33 PM   #24 (permalink)
brontosaurus
1vicissitude's Avatar
I believe they were not happy with the results and went back to the drawing board.
What bewilders me is how can itb setups gain power on NA builds, but none of these manifolds can gain power like itbs can in naturally aspirated situations? I would imagine a straight runner manifold with ~8.5" long runners, ~45mm in diameter, with a decent sized plenum, and with a larger throttle body could gain some power given the intake track wasn't restrictive. Perhaps something like an Arc chamber would be beneficial for NA power once the manifold/throttle could flow more air.
Ain't no MTn fast enough;
Ain't no RD low enough;
Ain't no Mnet stock enough;
To keep CR from swaggin wif you, babe.
1vicissitude is offline   Reply With Quote Quick reply to this message
