Question about removing Power Steering - ClubRoadster.net
Old 04-16-2012, 12:55 PM   #1 (permalink)
This is a long user title
invert's Avatar
Default Question about removing Power Steering
Hey all,
My power steering is leaking and not working so well.
I bought these plugs (6 I think) that are supposed to bolt right up where the power steering was.
My question : can I just remove the power steering pump/pulley/belt, remove some fluid and put those plugs ?
I just don't want to do the whole FM method that needs to remove something from the rack.
Let me know your thoughts.
Maxime L. | REV9 Autosport
AWD | CARBING | DAIKEI | JENVEY | JET STREAM | JUBIRIDE | NARDI | TRAP | TUCKIN99 | ZOOM | Many More!
Email:
| Web:
Contact me for any JDM part. New or Used, I can get them all.
invert is offline   Reply With Quote Quick reply to this message
Old 04-16-2012, 12:57 PM   #2 (permalink)
Accepting donations.
adamvanxxx's Avatar
What plugs exactly?
I just drained the rack with a few lock to locks and then just looped the lines.
Perfectly fine.
adamvanxxx is offline   Reply With Quote Quick reply to this message
Old 04-16-2012, 01:03 PM   #3 (permalink)
invert's Avatar
Default Re: Question about removing Power Steering
Originally Posted by adamvanxxx View Post
What plugs exactly?
Perfectly fine.
Is there instructions on how to loop the lines? Did you keep the PS belt/pump ?
Email:
| Web:
Old 04-16-2012, 01:22 PM   #4 (permalink)
With the plugs, you must remove the seal from the rack. The 'FM Method' really isn't very hard, and incredibly worth it. If you don't have access to a TIG, don't worry too much about welding the shaft, but removing the seal really makes a world of difference. If you are still set on leaving the seal, you need to loop the lines so you aren't fighting air pressure in the rack.
baron340 is offline   Reply With Quote Quick reply to this message
Old 04-16-2012, 01:25 PM   #5 (permalink)
whitebeau's Avatar
Talking Re: Question about removing Power Steering
The Dirty: has multiple links depending on your flavor.
De-power rack and pinion manual steering
no you will get rid of the pump assembly & associated belt , just take the line to the rack after getting the PS fluid out, then get it loaded with grease, then loop the line. I've been thinking of doing this some weekend.. once i get rid of other gremlins.
Wait a second, I make a thread about anal sex and get banhammered, and you make a thread that is a BLATANT UNTRUTH AND IT IS ALLOWED?!?!
^I really hope you can see the difference between those 2
whitebeau is offline   Reply With Quote Quick reply to this message
Old 04-16-2012, 01:37 PM   #6 (permalink)
adamvanxxx's Avatar
I didn't load it with grease just drained and lopped.
Works fine has worked fine over an entire year not hard at all. Easier than my civic was.
Old 04-26-2012, 01:46 PM   #7 (permalink)
I may have to try this. Looks easy enough.
mpage04 is offline   Reply With Quote Quick reply to this message
