Rivets, screws, bolts? What do I use to install fender flares? - ClubRoadster.net
Go Back   ClubRoadster.net > ROADSTER STYLE & AFTERMARKET > Exterior - *Sponsored by R-Speed*
Exterior - *Sponsored by R-Speed* Appearance related topics including Body Kits, Stripes, Paint, Tops, and Lighting and more!
Old 03-30-2012, 05:34 PM   #1 (permalink)
PaKMaN's Avatar
Default Rivets, screws, bolts? What do I use to install fender flares?
can anyone tell me where to get these from?
GT30R powered 1994 Mazda Miata
2000 Mazda Miata
PaKMaN is offline   Reply With Quote Quick reply to this message
Old 03-30-2012, 05:35 PM   #2 (permalink)
Default Re: Rivets, screws, bolts? What do I use to install fender flares?
rivets for sure, basically any hardware store
It's Ryan. is offline   Reply With Quote Quick reply to this message
Old 03-30-2012, 05:42 PM   #3 (permalink)
PaKMaN's Avatar
Nice, thanks Ryan.
2000 Mazda Miata
Old 03-30-2012, 05:54 PM   #4 (permalink)
supercharged-miata's Avatar
they have rivets that you can thread a bolt into so you can take them off with out having to drill them out. i forget where i saw them or what they were called. sorry
10AE #2348
360whp SR swapped maddness!!!!
supercharged-miata is offline   Reply With Quote Quick reply to this message
Old 03-30-2012, 06:01 PM   #5 (permalink)
mcmaster
kenji815 is offline   Reply With Quote Quick reply to this message
Old 03-30-2012, 06:02 PM   #6 (permalink)
Haerie Ballsagna
concealer404's Avatar
"Rivnuts."
Originally Posted by Corky Bell View Post
Understanding how it works and even it's limitations doesn't really matter.
Save Callie's Knees! http://www.gofundme.com/htfg18
concealer404 is offline   Reply With Quote Quick reply to this message
Old 03-31-2012, 12:01 AM   #7 (permalink)
Boostedmx5's Avatar
You can get rivnuts or you can use these special dry wall screws that flare out behind whatever they screw in. Tbh they work awesome.
Boostedmx5 is offline   Reply With Quote Quick reply to this message
Old 03-31-2012, 01:14 AM   #8 (permalink)
nanotech's Avatar
I'm still yet to install mine but what I've bought is a set of rivnuts, small washers and socket head bolts.
The length of the bolt shouldn't matter too much as long as it's long enough. A little too long should be fine as they bolt up quite high so tyre contact won't be an issue. Just keep in mind that if you do put in shorter bolts, you will need longer ones for the bottom corners of the flare; the two that go under the indented line on the body of the car and the bumpers.
This has been said before but just to go over it again, rivnuts are threaded rivets which you can punch into your fender. These will make taking the flares on or off (for whatever reason) SOOO much easier as it acts as a captive nut. Just make sure you don't do the bolts up too tight as fender flares are just fibreglass and aren't very thick.
If you are a noob like me though, your best bet is to go into your local nut and bolt shop and get them to come out to the car with you so they can tell you what bolt length to use. This helped me a lot since I'm not very up with bolt length and thread sizes.
One thing to keep in mind is that you cannot load rivnuts into a basic rivet gun. you'll need a 'rivnut gun' which is quite a bit more expensive. Put a word on the forum and see if there is anyone local who can lend you one, otherwise just hire them.
Hope I've helped you mate
nanotech is offline   Reply With Quote Quick reply to this message
Old 03-31-2012, 03:39 AM   #9 (permalink)
hks_kansei's Avatar
Hammer and nails.
http://img188.imageshack.us/img188/315/imgp0287qp.jpg
NB8A Twilight Blue - Voodoo, vent rings, RS*R catback, Brown Davis bar
hks_kansei is offline   Reply With Quote Quick reply to this message
Old 03-31-2012, 03:44 AM   #10 (permalink)
320icar's Avatar
I plan to use the spare bolts from my bbs wheels. That way the flares can be removed anytime for body repair
320icar is offline   Reply With Quote Quick reply to this message
Old 03-31-2012, 07:07 AM   #11 (permalink)
Boostedmx5's Avatar
http://www.carolinarovers.info/croc-...wn-rivnut-tool
You are welcome.
Old 03-31-2012, 08:14 AM   #12 (permalink)
nanotech's Avatar
Sick as bro! Cannot wait to try
Old 03-31-2012, 08:30 AM   #13 (permalink)
Boostedmx5's Avatar
Lol.
