Guys, the power antenna on my NA is snapped off. Motor works great but nothing raises or lowers(since its missing) what is a good replacement for it. Looking to possibly get rid of the motor all together. Been looking around and just cant seem to find anything...so whats out there? Recommendations?
It looks great, sealed up very nicely, and works like a champ. The install was pretty easy too. It does require cutting and splicing one wire, but there's really no way around this with any replacement. I used some crimp-on connectors so that if I want to I can quickly disconnect and go back to stock. I can't think of any reason I ever would though.
Ive got the one similar (or the same, who knows) to the Shark Attack that Moss sells. Looks good, easy install. Only issue is radio reception took a hit.
Electric mast, #902-475. Shorty, #906-185. Plugs into the wires in your trunk but it also comes with wires (if you don't need them you can use them for something else). I put one on my 1990 because I'd removed the fixed tall stalk antenna, reception isn't great but better than no antenna. Other antenna options at Moss.
