HID lights in reflector housings- A reminder to some of you out there. - ClubRoadster.net
Go Back   ClubRoadster.net > ROADSTER STYLE & AFTERMARKET > Exterior
Exterior Appearance related topics including Body Kits, Stripes, Paint, Tops, and Lighting and more!
Old 02-04-2013, 03:59 PM   #1 (permalink)
Lit like a BranchDavidian
Doppelganger's Avatar
Default HID lights in reflector housings- A reminder to some of you out there.
Ok, another fun rant for everyone...well, maybe not everyone. Those of who you care about "doing things right" and research your modifications before installing them, I'm not looking at you. Yes, there are correct ways to retrofit HIDs into your car that came with reflector housings. If you have done this, thank you and good job. If you have OEM projectors and have put HIDs in, then you're fine as well. The ones I am looking at, again, are those who blindly throw parts at their cars without even the basic understanding as to what they are doing. Today's focus is lighting. With the introduction of H.I.D (high intensity discharge ) or "Xenon" lighting in automotive applications, drivers have been given a better and safer way to see at night....mostly. This types of lights started out as OEM options and have slowly (well, back then) trickled their way down to the average consumer for a low price. At first, to have Xenon lighting in a car that did not come with it required getting a hold of an OEM setup, which was (and still is) very expensive. As aftermarket manufacturers saw the demand for these kits, they flooded the market with them for every automotive bulb under the sun. While a benefit to some, it has been a glaring problem to many motorists. Far too often, owners who like to modify their cars have been like horny leg-humping dogs by sticking these lights in every hole they can think of...weather they belong there or not. Not only have the applications of many of these lights been wrong, manufacturers have even gone as far as to manipulate the technology of these light to produce some of the most annoying and unusable lights ever conceived.
Let's look at a few basics.
Reflector vs projector housings..in one simple picture-
What is a H.I.D/Xenon bulb anyway? Well, your standard halogen bulb that has been standard for decades is nothing different in design than your typical household light bulb. It works by passing energy over a small filament which in turn causes the filament to become super heated and produce light. We should all understand how this works. Like this-
In HID or Xenon lighting, a small arc of plasma is created by energy passing through various gases and elements in a sealed chamber. This arc produces the light you see..it's kind of like a small lightning bolt to put it in simple terms. It works like this-
Let's discuss the two types of light bulbs and the two types of light housings used on cars today.
Now for a general light, this really is no different other than overall light output. The HID is able to produce a brighter light with less energy. But when it comes to automotive applications, things change...a lot. Automotive lights are designed in a very specific manner in order to put light where you need it, and not put light where you don't, as in putting light on the road and not in oncoming driver's faces. The general standard for years has been a halogen bulb in a reflector housing. In this housing, bulbs have a shield built into them to help control light output. Think of it like walking though a dark room with a candle to light your way. Notice that when you do this, the glare from the candle hurts your ability to see what you are trying to light up. What do most people do? Well, instinctively most people put their hand between their eyes and the candle. This is the same concept on most halogen bulbs and is designed to only allow light into a specific part of the reflector housing. You can see it here as a little piece of metal next to the filament-
And this is the desired effect of all of this. The location of the filament and the shield are super critical in the design of a reflector, changing the location of the filament's location even a couple of millimeters will change every angle at which the light travels, ultimately letting light go in places it was not designed to. This is is also the exact same reason why your high-beams project light much higher and wider- because the high-beam filament is no shielded and placed in a location that causes the light to scatter in a different direction.
There are many cars with projector lenses that use halogen bulbs. But the bulbs used in the projector housings do not, I repeat, do not have a shield on them. This is because the way a projector housing works, the lens (and if applicable, the shield build into the housing) does all the focusing. In some projector setups, both high and low beam patterns are available and are controlled with a movable shield. Here is an example of what I am talking about-
..and this is how a projector housing works-
Now when it comes to HID lights, almost all of the cheap/regular kits for most all bulbs are unshielded. There are a few exceptions that have a shield operated by a solenoid, but generally speaking most, if not all of your average HID installs in reflector housings are done wrong.
You average HID bulb looks like this-
Notice the little bubble in the middle? That is where the arc is produced and where the light comes from. Notice the difference in the following picture of the location of the halogen filament vs. the location of the HID "filament". This is the root cause of why putting HIDs in reflectors is never a good idea-
Upon changing the location of the actual light source, you get massive amounts of light scatter (glare). This is what is very bad and annoying to all other drivers on the road. You are essentially blinding them as if you were driving with your high-beams on. I've heard many people exclaim "but I can see so much better with my HIDs (in reflector housings)"...and this is only true because you are scattering light all over the place. Here are some examples of what I am talking about-
Halogen in reflector-
Halogen in projector-
HID in reflector housing-
Notice all the light scatter/glare that is up higher than the "cut off" line? That is bad...very bad. I could post up numerous examples of this all day long. Even while it "might not look so bad", it is bad. Aiming your headlights down won't help any either. All aiming your lights down will do is move the focus point down, but glare will still be emitted up and out. Oncoming drivers will see this. Most people might thing your brights are on too....even though they're not. Both of the car in the following picture are equipped with traditional halogen reflector housings..but one of them had improperly installed HID lights, can you tell which one is which?
See how bad that is? Sadly, none of the people doing this actually care they are blinding other drivers...nor do they really listen to those who care to inform them politely.
Lastly, we have color. For whatever reason that I may never understand, people seem to love the blue/pink/purple lights too. They think it looks "cool" or that they can see better with it. In fact, no matter what the reasoning is, they are 100% dead wrong. HID lights, as many know, are offered in different "K" ratings. This is for Kelvin. The Kelvin range describes light at different frequencies. Here is a simple way to understand Kelvin (K) and light output-
In reality, anything above 5K is really not any more helpful or useful to the human eye. In fact, the lower the Kelvin rating, the "better" it is for your eyes. Natural sun light is actually pretty yellow. Regualr halogen light is also on the yellow scale. The human eye likes this and is why we can see the colors we see. Notice with a blue or red light how everything looks a single color? This is the same for HID lights in the 8K+ range. Your eye does not like the frequency and takes much longer to adjust as well as a severe loss of detail when looking at something. This is actually why police lights are blue...because they're VERY attention getting and police want you to see their blue lights from as far away as possible...so you know they're there. Blue/purple/pink headlights are terrible for your eyes. I could actually give much more detailed information as to why, but I don't need to be that technical right now. Just know, and please understand why all of this is so bad.
TL;DR? Just read this:
If you put HIDs in your car and they don't look almost exactly like this-
Then you are doing it wrong and irritating everyone driving down the road at night.
If your lights looks like this..regardless of the HID in reflector housing...
...you are a complete and useless ricer who shouldn't be allowed to own a car.
2002 Ti SE Turbo
Doppelganger is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 04:09 PM   #2 (permalink)
Default Re: HID lights in reflector housings- A reminder to some of you out there.
I one am one of those drivers that gets super pissed when someone is blinding me on oncoming traffic. So annoying and can be dangerous. Thank you Doppelganger!
Willywongka is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 04:14 PM   #3 (permalink)
shiz's Avatar
I hate it when lifted trucks have those. It feels like my retinas are burning
My build so far.
Rotrex/Ohlins/AEM/Mazdaspeed/Momo/Blackbirdfabworx/RacingBeat/Infinifab
Follow me on IG, daricerocket
shiz is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 04:33 PM   #4 (permalink)
mrsuave's Avatar
Hopefully everyone gives this a good read! I'm going to retrofit nb1 lights to replicate craft square's light!
97 NA parts car
VRGT msm #31 sold*
MY04 BB s2000 Sold*
96 m45 dd
mrsuave is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 04:37 PM   #5 (permalink)
Hide yo kids hide yo wife
batou's Avatar
Good info for the newer members, or those just looking to increase light output. Stickied!
batou is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 04:38 PM   #6 (permalink)
(/゚Д゚)/
33oh's Avatar
I totally agree with you.
Just want to add one thing; You do not NEED a projector housing for an HID. There are HID bulbs that are designed to go into reflector housings. An arc bulb that is designed for an HID projector will be labeled as a D"*"S bulb, and an arc bulb designed for an HID reflector will be labeled a D"*"R bulb. The majority of the aftermarket kits (99.9%) are D"*"S - so yes, your information is still relevant. Just wanted to throw that in there since it is an option; not all HID's + reflector housings = bad. (Hell, some cars came stock equipped with HID's and reflector housings.)
The main point is the same; if the type of housing isn't designed for the type of bulb, don't put it in!
33oh is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 04:41 PM   #7 (permalink)
circlejerk911's Avatar
i have an nb1 an plan to throw HID's in. the way i look at it ( dont take this srsly) is since im low and everyones lights blind me, its time to get revenge, even the dudes i drive with blind me while im in front of them. and they all have proper projectors. so they got it comin!!!!!!! and those dweebs with lifted trucks can fuck right off
circlejerk911 is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 05:33 PM   #8 (permalink)
Tungsten6's Avatar
^coughmoroncoughcoughcough
Projectors or bust.
Instagram: Awelch1204
i bought an ebay gf - she doesn't cook, clean or make me sammiches.
i feel your pain
Tungsten6 is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 05:42 PM   #9 (permalink)
itzzspencer's Avatar
ugh my eyes hurt just from looking at those last pictures
5/8/15. rest in paradise Marco.
itzzspencer is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 05:53 PM   #10 (permalink)
sw96's Avatar
LOTS of good info here. A+
sw96 is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 07:20 PM   #11 (permalink)
Projectors or bust.
it was a joke, relax. im probably gonna retro fit projectors in when my car is running
Old 02-04-2013, 07:29 PM   #12 (permalink)
I ordered some 4500ks and they still look a little blue :[
kashmir is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 07:49 PM   #13 (permalink)
epic post of what i've been trying to explain to the ricers for years...
it never works though.
2005 Mazdaspeed Miata - Lava Orange #225
2012 Ford F150 5.0
TheFrohn is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 08:25 PM   #14 (permalink)
95montego's Avatar
this should be stickied!
95montego is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 08:53 PM   #15 (permalink)
Nicktorius's Avatar
2007 Mazda 3 - Black Mica
2005 Mazdaspeed MX-5 - Black Mica
2000 Miata - Evolution Orange Mica
1993 Miata - Crystal White
Nicktorius is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 09:34 PM   #16 (permalink)
Chase!'s Avatar
Very good to know.
- Current Project
- Sold
- Sold
09 R6 & 08 Altima Coupe 3.5 SE - DD's |
Soul brotha. Taking all our wiminzzz. Lol
Chase! is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 10:15 PM   #17 (permalink)
ColbyDangerJones's Avatar
Good information. I never even looked into HIDs because I was so annoyed of everybody else and I didn't want to be one of them.
This tells me that I could definitely run HIDs without blinding people if I wanted to. Props.
ColbyDangerJones is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 10:54 PM   #18 (permalink)
Dustinlib's Avatar
i have some 8k's i've been putting off installing. i'm such a ricer.
Dustinlib is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 11:04 PM   #19 (permalink)
you just shead light on something i have been saying for years, thank you for that...
i know its long but here you go, a very instructional video on how retro fitting an HID kit is suppose to be done.
http://www.youtube.com/watch?v=QHQ2oO-NMJ8
CooTcRUSHer is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 11:05 PM   #20 (permalink)
presidential's Avatar
Since I am so tired of explaining this to brodozers and ricers, I'm just going to linkback this thread from now on. Thanks for posting it.
i've been an alcoholic for a while now...wouldn't have it any other way.
presidential is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 11:10 PM   #21 (permalink)
'Bout dat life
reversecaoboy's Avatar
Strong post. Good information here for people.
I had looked into retrofitting some projectors. But I'm too cheap for that. So halogens it is....
99 NB
reversecaoboy is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 11:16 PM   #22 (permalink)
I can spot an 'improper' HID install from a mile away. Insane glare.
Thankfully, they don't seem to be that common.
I would caution that, while a halogen projector will handle light better than a halogen reflector, it still may not be 'correct' for the HID's. The ideal would be to replace the factory projector with an HID unit.
I think a few of the reflector type HID's were the Lexus LS400, Acura TL, Acura CL, and Acura RL from years past. Now everyone's got projectors it seems, with the new thing being LED headlights.
08_ms3_gt is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 11:16 PM   #23 (permalink)
Prices aren't too bad these days on retrofit parts. Back 4-5 years ago, stuff wasn't as plug and play and was more expensive. Uphill, in the snow, both ways.
Old 02-05-2013, 08:46 AM   #24 (permalink)
Yeah, I see it all the time here- mostly with the ghetto crowd and the ricers. I have HIDs in my OE housings and after much analysis, they seem to be ok/proper. Remember that all headlights have a small amount of glare designed into them to illuminate things above the cutoff line.
Oh, another side note, the light waves of HIDs compared to halogen is also different, which adds to the annoyance of improperly installed HIDs.
Here is a good article explaining the differences of glare and light from HIDs vs halogen bulbs.
Finally, if you want to read a very in-depth article about HID vs halogen and light spectrum, here is a great article.
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC1771460/
2002 Ti SE Turbo
Old 02-05-2013, 10:03 AM   #25 (permalink)
Mx-p5's Avatar
I support this thread!
Protege to MX-5 lineage
Kevin did it before Phil did, Phil was before Andrew, who was before Bruce, Chris, Tony, Phen, Tylor, Mahk, Roy, John, Jerry, Rob, Shadow, Josh, Scratch, Dub, Andrew, Vocko, Matt V, Protojason, chiefmg, Barry, Tungsten, and Me again
Mx-p5 is offline   Reply With Quote Quick reply to this message
Old 02-05-2013, 10:22 AM   #26 (permalink)
So now that we have this awesome thread, I wanted to ask about these headlights off eBay. I'm in no way an hid baws or anything but they look to be projectors. But the price has me iffy. Oh and if these turn out to be genuine I won't be going with the 6000K.
pricklydick is offline   Reply With Quote Quick reply to this message
Old 02-05-2013, 10:38 AM   #27 (permalink)
Mx-p5's Avatar
those are NOT projectors
They're halogen reflector lights with a lens stuck in front of it to LOOk like aprojector
Old 02-05-2013, 10:41 AM   #28 (permalink)
those tricky bastards.
Old 02-05-2013, 11:41 AM   #29 (permalink)
Nile's Avatar
Thanks for the info! Really helped!
Sent from my DROID X2 using Tapatalk 2
Nile is offline   Reply With Quote Quick reply to this message
Old 02-05-2013, 01:58 PM   #30 (permalink)
tom550's Avatar
If Mx-p5 supports this thread then I support as well.
tom550 is offline   Reply With Quote Quick reply to this message
