Fuel Guage not working - ClubRoadster.net
Go Back   ClubRoadster.net > ROADSTER STYLE & AFTERMARKET > Interior - *Sponsored by REV9 Autosport*
Interior - *Sponsored by REV9 Autosport* Here's the spot where you talk about the place you spend most of your time!
Old 07-30-2006, 11:33 PM   #1 (permalink)
CR.net Old Geezer
NA3Turbo's Avatar
Default Fuel Guage not working
Tonight I took my cluster out to replace some burnt out bulbs. After replacing all of them and hooking the plugs back up I noticed that my fuel guage didn't work but everything else does. The needle is maybe a quater inch below "E." I even removed the cluster a second time and made sure I had all of the plugs in Correctly. I know I have gas because I had filled up not 5 minutes before I started ripping things down. Anyone have any ideas? I'd like to fix it ASAP.
NA3Turbo is offline   Reply With Quote
Old 07-31-2006, 12:57 AM   #2 (permalink)
CR.net Old Geezer
NA3Turbo's Avatar
Problem solved. I had a small rip in the plastic electronic backing of the cluster that a little dab of solder fixed right up.
