how to remove steering wheel with airbag ? - ClubRoadster.net
Go Back   ClubRoadster.net > ROADSTER STYLE & AFTERMARKET > Interior - *Sponsored by REV9 Autosport*
Interior - *Sponsored by REV9 Autosport* Here's the spot where you talk about the place you spend most of your time!
Closed Thread
Old 09-22-2009, 11:00 PM   #1 (permalink)
Default how to remove steering wheel with airbag ?
ok so my wheels are straight but my steerign wheel is off. so im gonna set my wheels straight and "reset" my steering wheel. now comes the hard part. how the hell do i take off my steering wheel without setting off my airbag, or making it un-usable. i herd if i disconnect some crap the airbag wont go off or something. but anyways. how do i remove the steering wheel. what do i pull? where are the bolts/nuts? pictures would be great. thanks in advanced
lsx240 is offline   Quick reply to this message
Old 09-22-2009, 11:03 PM   #2 (permalink)
SuperMOD
AntiochOG's Avatar
Default Re: how to remove steering wheel with airbag ?
This should help.
1990 Miata - Red, DIY roll bar, hardtop, Bilsteins/GCs, Randall CAI, Raceland header, RPF1, RT615k, 9 lb. flywheel
AntiochOG is offline   Quick reply to this message
Old 09-22-2009, 11:05 PM   #3 (permalink)
kindakouki's Avatar
this is pretty much universal for any car. look on the sides of the steering wheel, should be a rubber cap on each side, pop them off, take out bolts, pull out airbag and unplug, then lock steering wheel and undo giant bolt in middle.
NC MX-5 Formula D Pro Am Driver
2.5L / Garrett GTX Turbo
Lone Star Drift
Moto-East Tuning
kindakouki is offline   Quick reply to this message
Old 09-22-2009, 11:10 PM   #4 (permalink)
Supporting Member #5522
j-radvw's Avatar
or you can just get it aligned or just jack it up and turn your alignement nuts and do it the right way
Miata Build thread
Jeep build Thread
911 build thread
j-radvw is offline   Quick reply to this message
Old 09-22-2009, 11:16 PM   #5 (permalink)
im re aligning the steering wheel because it was so far off and then im getting it re aligned at a shop. sound good to you boo?
Old 09-22-2009, 11:22 PM   #6 (permalink)
j-radvw's Avatar
how far is so far off if? you have never had your steering wheel off i would be worried that your stering rack is out of place and just moving your steering wheel will make your car turn one way more then the outher.
Miata Build thread
Jeep build Thread
911 build thread
Old 09-23-2009, 12:02 AM   #7 (permalink)
long story short lowered my car then hit a curb and bent my rim, got that repaired and i tried correcting it by playing with the tie rod ends then i found out my lower control arm was bent so i replaced that so after i fixed everything my steering wheel faces at about 3 o' clock when my wheels are straight and it cannot be fix by getting an alignment so i must reset my wheel. make sense?
Old 09-23-2009, 12:15 AM   #8 (permalink)
j-radvw's Avatar
have fun
Miata Build thread
Jeep build Thread
911 build thread
Old 09-23-2009, 12:36 AM   #9 (permalink)
have fun
ok so i sense alot of sarcasm on that one. do you know something that i dont? you really think something else is bent huh ? like what. the only thing low enough to hit would be the lower control arm.,which has already been replaced, and when i put the new one in, everything lined up perfectly.
Old 09-23-2009, 02:12 AM   #10 (permalink)
808roadster's Avatar
Just get it aligned. It will tell you if you got the same angle both ways. If it aint then you can move things around. J was just helping :rolleyes:
808roadster is offline   Quick reply to this message
Old 09-23-2009, 02:51 AM   #11 (permalink)
Faded92Mx5's Avatar
Yeah it sounds to me like you just need to adjust the tie rods in the opposite direction than you did last time. What you're trying to do is a band aid fix. Get it close, then pay for an alignment.
But if you insist, there should be a walkthrough on removing the air bag in the m.net garage
Miata number 5 in ~10 years, a 95 Laguna blue. Koni Race shocks/coilovers, HDHCM1SD, Torsen, OBX header w/Racing Beat catback, Kosei K1/T1R, Revlimiter gauges
Faded92Mx5 is offline   Quick reply to this message
Old 09-23-2009, 09:05 AM   #12 (permalink)
guys guys guys i could have swore i already said that, the tie rods are screwed all the way in already they cannot be adjusted anymore, im gonna get the wheels straight and reset the steering wheel so i can drive it to get it aligned, of course im getting it proffesionally aligned. i just need to be able to drive it there safely
Old 09-23-2009, 11:30 AM   #13 (permalink)
I have the sack you want to ride.
mk2tmr2's Avatar
Get it professionally aligned first. Tell them to get the steering wheel straight. That's doing it the right way.
If the steering wheel still isn't straight - then do your jerry-rigging.
SKYRINE GT-R:
I used to have
And before that I had
mk2tmr2 is offline   Quick reply to this message
Old 09-23-2009, 12:07 PM   #14 (permalink)
LagunaMiata's Avatar
Moving the wheel would fix a SLIGHT misalignment, like a few degrees. If it's as off as you say, then you need to fix the suspension.
M.net has instructions. When I put on my aftermarket wheel I pulled the battery cable and walked away for 45 minutes to give the airbag capacitors time to discharge. Remember, the airbag is a bomb, just waiting for a little current to go off.
Rich Little
Carolinas Miata Club
Central Carolinas Region SCCA
LagunaMiata is offline   Quick reply to this message
Old 09-23-2009, 12:43 PM   #15 (permalink)
Custom Gauge Master
revlimiter's Avatar
45 minutes? Bah. Pull the battery and then hit your brakes. The lights will completely discharge your electrical system in less than a quarter second. And an airbag is HARD to set off. Just don't touch the terminals while you're walking around with it.
For real. It's not that big a deal.
and OP: just drive to the alignment shop with your wheel crooked. It's not the end of the world. They'll fix it for ya.
Adam
revlimiter is offline   Quick reply to this message
Old 09-23-2009, 01:11 PM   #16 (permalink)
just to let you guys know everything is fixed and about your little comment on driving to the alignment shop. its 45 mins away and one wheel is straight and the other one is like this ---> / . you try driving that with your steering wheel also 90 degrees off
Old 09-23-2009, 01:15 PM   #17 (permalink)
Sounds like you have a bent tie rod.
avante43 is offline   Quick reply to this message
Old 09-23-2009, 02:02 PM   #18 (permalink)
possibility but my alignment is good and my steerign wheel is straight so im gonna leave it alone
Old 09-23-2009, 03:01 PM   #19 (permalink)
BracedEunos's Avatar
Firestone. I think its $135 for alignment and you get them for lifetime. As long as you own the car, you get free alignments after that at any Firestone dealership.
What you could also do is have a buddy the same color car as your put on your plates and alternate! You both get free alignments! Handy if you own more than one miata.
BracedEunos is offline   Quick reply to this message
Old 09-23-2009, 03:10 PM   #20 (permalink)
mk2tmr2's Avatar
Or you could not be a dishonest scumbag and refrain from theft of services.
SKYRINE GT-R:
I used to have
Old 09-23-2009, 03:15 PM   #21 (permalink)
Custom Gauge Master
revlimiter's Avatar
and with that, we're closed.
Adam
Closed Thread
