#1 (permalink) |
Finger lickin' good...
Who makes them? I'm looking for a new suspension setup. Ultimately, I'd love to have some of the better known systems, but I'm unsure if they are in fact rebuildable/servicable. I've searched before I posted this topic and only came back with 4 resuts, all were budget Koni's w/ GC sleeves. I'm not ruling that out, but how well/often can Koni's be rebuilt? What is their limitations as well? Now, when I ask if they can be rebuilt/serviced, I'm talking say a seal blows and oil leaks out. Can I buy just the seal that's blown as well as any other seal that fluid may have gotten by, put it all back together, refill with oil, and repressurize w/ Nitro, or will my only option have to be to completely replace the entire shock (damper) or coil-over?
Examples of dampers/shocks/coil-overs are: Ohlins, Tanabe, Cusco, Bilstein, Stance, JIC Majic, 949 racing, Megan, etc. please help a feller out
Andrew - '98 Honda Superhawk - '88 Yamaha YSR50 - "Play Thing" - '78 Honda CB750F SOHC SuperSport - "Lucky 13" |
#3 (permalink) |
And the only real limitation of the Koni yellow in a coil over configuration is the lack of adjustable shock length. As you lower the spring perch to get the car lower you lose useable bump travel. But, you can get Koni's shortened at around $71 per shock. Add to the price of the rebuild $125 plus parts
The only problems I have seen with yellows are SA's that have been converted to DA's. A very small percentage will develop leaks when not done by Koni. ProParts for example did some shocks for a friend of mines MRSpyder and he had a hell of a time with them. But the two time DStock national champion has been driving around on Koni converted DA's for a few years now with no problems. I've also seen a set of Penske's go back to the builder 3 times in one season for leaks. So money spent is no example of quality. Finding the right solution for your situation is. Penske's are great! They just don't always like street miles. |
#4 (permalink) | |
#5 (permalink) |
I don't know for sure but I've heard that Tein has a service facility in the states.
I know from experience that companies like KSport do not. They would replace an entire damper if a problem developed. FCM does rebuild Bilsteins as well as Bilstein direct. From what I've found is that companies are quite forthcoming if you call them, like Stance, JIC etc. |
"The difference between genius and stupidity is that genius has its limits." Albert Einstein |
#9 (permalink) |
Keep 'em comin guys, you're helping me immensely =D>
#11 (permalink) | |
FUCK YOU!!!!
#12 (permalink) |
ohlins
guess what I drive... http://speedhunters.com/archive/2009...vo-tumble.aspx www.worksmotorsports.com http://worksmotorsports.blogspot.com/ |
#13 (permalink) |
Any thoughts on the BC Coilovers? I know Chelsea was running them on his drift car. Marty and I met the guys at SEMA, and they seems to have their act together. When Im ready for coilovers, I think I will give them a shot (this is several months out though).
#14 (permalink) | |
