#1 (permalink) |
Nielex Steering Rack Brace
![]() ![]() What's the verdict on this thing? How beneficial is it? It appears to fit both PS and manual racks. Is this just bling or is it the last piece of the puzzle for achieving steering nirvana? |
#2 (permalink) |
The Vorlon
Hmmm...never seen it before.
__________________________________________________ __________________ http://www.youtube.com/watch?v=60loeoblu0M |
#3 (permalink) |
I can't really see how it'd help... it mounts to the same places as before. Looks like all it does is brace the rack itself... against itself... except that it's already tubular.
Color me skeptical. |
-Matt '05 Elise, '99 Neon. No more Miata... for now. |
#4 (permalink) |
Guest
Posts: n/a
I've had my eye on this for a couple of years. (Damn, Mr. Woolery, you need to buy R&S once in a while!)
After burning myself a few times ordering expensive JDM parts that turned out to not fit RHD cars, I've been waiting for someone else to get one of these and confirm: 1) If this will even fit LHD cars; 2) If it makes any difference in steering feel or handling I hope this thread brings someone out of the woodwork who can answer those questions. BTW, I like how they improved the design over their original one, making the cross-brace out of extruded L-shaped stock and overlapping it with the ends to reduce flexing. The added drain holes at the bottoms of the countersunk holes are smart too. Bill |
#5 (permalink) |
The question is, Does it do anything?
Let's see: Wheel spindle assembly is conected by the upper and lower A-arms. A-arms are bolted to the car. Tie end rods connected to steering rack. It seems to me that all the stress would be put on the upper and lower A-arms. The tie rods would serve one purpose, to steer the wheels. I think if the engineers would want to "stiffen" anything, it would be the skinny tie-ends. Correct me if I'm wrong in my logic. |
#7 (permalink) |
As a engineer of things that aren't roadsters... what about something like the honda guys have.. the Korbach Frame Locks.
http://www.korbachperformance.com/framelocks.htm They're supposed to really tighten up the chassis and improve steering feel. which on a civic is a big deal because they have about .0003 degrees of caster. do we have a similar weak joint at the front corners? |
miataturbo.net envoy |
#8 (permalink) | |
Guest
Posts: n/a
With its PPF, the Miata chassis has a strong skeleton down the center of the car vs. the Honda being like box with 4 floppy corners. Plus, being FF, all the torque in the Honda is in the front of the chassis. The FR Miata spreads the torque throughout the chassis. Someone please correct me if I'm wrong. |
#9 (permalink) | |
Guest
Posts: n/a
Protects the rack from road debris (if you're not running the plastic tray). Lowers the center of gravity (by adding more weight at a low point). Lightens wallet (which ironically raises the center of gravity back up again). |
#10 (permalink) | ||
The Vorlon
#11 (permalink) |
Mufasa in Training
I doubt that it'd protect the rack from anything...there's not any kind of shield on it. Of course, if you're running the undertray, it's a non-issue, anyway.
#12 (permalink) |
Looks like a peice of jewlery for your engine bay. I can't imagine it doing anything for your driving experience. Protect the rack from what? A boulder???
1992 Miata w/ 2002 F20C swap. Comptech Supercharger/ aftercooler, 95 Diff w/LSD. Other stuff too... http://www.youtube.com/watch?v=cMWpb8wq9qg |
#14 (permalink) |
haha.. I thought you were reading from the site
#16 (permalink) | ||
Mufasa in Training
#17 (permalink) |
looks like a waste of $$$.
urethane bushings for the steering rack would do the same thing....and i can't see that being beneficial unless the old rubber bushings are shot. |
Man, you know what reminds me of a 240sx? The 1984 Cadillac Eldorado. - VitaminT |
#18 (permalink) |
I was about to type something about this.
I have some urethane bushings to replace the old rubber units on my WRX which are prone to early death. I'm one of the lucky guys who hasn't needed it yet, probably because I put about 6K miles on the car per year average. |
#19 (permalink) |
Google-san says
"It eases the input from the road surface by improving steering wheel rack support rigidity, the steering wheel vibration is lightened, actualizes the linear steering wheel." |
"If you had access to a car like this, would you take it back right away? Neither would I." |
#20 (permalink) | |
I wish someone made poly rack bushings for the Miata. . . |
#21 (permalink) | |
The Vorlon
#22 (permalink) |
Does that make any sense to anyone??
#23 (permalink) |
Lost
Supports the steering rack and gives a more direct steering feel/input to the road and gets rid of steering wheel vibrations...I think that's what it says atleast
