Problem with TC Sportline control arms - ClubRoadster.net
Old 03-21-2009, 04:21 PM   #1 (permalink)
Default Problem with TC Sportline control arms
So i bought a set of tc sportline upper control arms. When i went to put them on, they would not fit. my question to you is those bushing that come in the tie strap do i use them or no? do i have the grind them down or something has anyone had a problem with these? let me know pro favor.
-papo
papodotcom is offline   Reply With Quote
Old 03-21-2009, 04:28 PM   #2 (permalink)
Kicked off the island..
Miatadam's Avatar
Maybe your subframe is bent? If not, its easy to just hammer it out just a little put the control arm in, and squeeze it back into the bushing with the nut and bolt on each side.
My 5.0 miata build: http://tinyurl.com/cv329ly
Miatadam is offline   Reply With Quote
Old 03-21-2009, 05:29 PM   #3 (permalink)
Esteemed Member
slutz4's Avatar
you can grind down those bushings or bend mounting tabs, take your pick. There made like that..
slutz4 is offline   Reply With Quote
Old 03-21-2009, 08:43 PM   #4 (permalink)
would it matter if i grind down the bushings? how did you do it to have them on your car?
Old 03-22-2009, 12:36 AM   #5 (permalink)
darkdrifter's Avatar
biguillio and i ground down the spacer/bushings.
then they fit like they should out of the box.
Originally Posted by Nev View Post
So what he's really asking is: "can my car drift with itbs and some bolt ons?" and the answer is, "holy jesus christ shut the fuck up."
Originally Posted by Roadster Dave View Post
I never dawned on me that being slammed was so bad for the environment.
darkdrifter is offline   Reply With Quote
Old 03-22-2009, 01:02 PM   #6 (permalink)
You are ofcourse installing them in the correct place?
(Just checking).
-n
nope-mx5 is offline   Reply With Quote
Old 03-22-2009, 08:09 PM   #7 (permalink)
yeah thats wht i did the first day i grinded the bushing a little but i didn't know it that was what was suppose to be done, i guess this is the route im going to have to go. i wish they would of put it in the discription that they dont fit right out of the box would of saved me so much time.
thanks for the input.
-papo
Old 03-26-2009, 01:18 AM   #8 (permalink)
Default Re: Problem with TC Sportline control arms
I posted a thread not to long ago about the same issue, searching will help in the future before buying. Wish someone would have talked about the issues before I bought them....
Bryan858 is offline   Reply With Quote
Old 03-26-2009, 09:24 PM   #9 (permalink)
doward's Avatar
If a car with as much factory adjustent as a miata is actually ready and/or needs a set of adjustable rucas IN ADDITION to the factory cam bolts, the owner should expect a not-so-plug-n-play experience with certain things.
It comes with the territory.
94 M, 1.9l 99 head, Honda IM, AEM EMS, 142whp, NB subs/arms/spindles/Sport brakes, 9"/225, 700/400. My build thread
doward is offline   Reply With Quote
Old 04-04-2009, 10:35 PM   #10 (permalink)
Umm no, We are not buying universal parts. I purchased a set specific to my make and model so it should have been plug and play. I could understand if a few of us have issues since are cars are getting old and maybe have seen more abuse than others but for everyone to have the exact same issue something needs to be corrected during the manufacturing process of the arms....
